That is correct, your tonearm needs to be replaced.
By adjusting that top screw on the tonearm, you only made the problem worse. It's very hard to realign that screw, as those are machine calibrated, and once tampered with, almost impossible to get back to exact factory settings. We recommend replacement of the entire Technics tonearm.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
Might need new tone arm dude
SOURCE: Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
