Question about Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only
Emerson DVD Recorder -RW/-R. Will not record. Get an error message: RECORDING ERROR. CANNOT RECORD ON THIS DISC. E4 54037380. Using a Memorex DVD-R 16X 4.7GB 120min
Posted by Skip Harwell on
Mark Sandmeyer
    Problem Solver:
  • 24 Answers
It may have macrovision and and that may be the case. its encrypted , from ever being recorded.
Posted on Jun 10, 2014
5 Related Answers
Anonymous
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
Anonymous
SOURCE: Emerson EWR20V4 that wont record DVD's
Sure, My suggestion is to call 1-800-605-8453, They will be glad to help you with that error code!
Good luck
Posted on Feb 08, 2008
Anonymous
SOURCE: cannot record on DVD-RW disc
I CHANGE DISK 4 TIMES WITH THE SAME RESULT
Posted on Dec 23, 2008
Anonymous
SOURCE: Emerson DVD Recorder EWR20V
Called the funai's service tech line at 1-800-605-8457. They will sell you a firmware update for 23.00 shipped that will allow it to use up to 8X DVD-RW. I'm using memorex 2X DVD-RW (RITEKW01) I got from walmart. They seem to work OK although dubbing on my deck doesn't seem to work. Probably unrelated.
Posted on Jan 19, 2009
Anonymous
  • 9 Answers
SOURCE: Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Posted on Feb 07, 2010
EWR20V5 loads but get "error message" Using Verbatum 4xDVD+RW disc with downloaded pictures from PC using Windows 10. Recorder works and video displayed on other discs.
Unfortunately, the EWR20V5 does not handle DVD +R or DVD +RW discs for recording. It can play back some of these discs, when recorded and finalized on another recording device. However, it may not recognize some DVD +R/+RW discs at all. This recorder recognizes all DVD -R/-RW discs. This is a common manufacturing design for DVD/VCR recorders.
See the first page of the Quick Guide for the EWR20V5 for the disc limitations: https://www.manualslib.com/manual/46971/Emerson-Ewr20v5.html . I hope this helps.
Aug 20, 2018 | Televison & Video
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Won't record and never has. get disk error e24
Anyone know where I could get a free download for a Emerson Dvd/vcr combo firmware upgrade??? (Ewr20v4) I need it right away . Emerson will charge to mail me one.
Nov 14, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Cannot record on DVD-RW disc
Somtimes if you change brands of dvds will help!
Dec 13, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Good luck
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Emerson DVD recorder EWR20V4 My DVD Recorder will not record on DVD-r or DVD-rw disc of any brand.Displays can not record on this disc. Shows E24 At the bottom of diplay.
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
May 14, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only Logo
527 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
