Primavera Contractor 6.1 Full Version for PC  Logo
A
Anonymous Posted on Feb 17, 2014
Errors located: WBS Name: Unique constraint (Parent,Project ID,WBS Name) violated. The value CE 142 - Condensate return line Steam Traps of the field WBS Name already exists. WBS Code: Unique constraint (Parent,WBS Code) violated
Derek Rae
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 05, 2018
Derek Rae
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
469
Points
Found when using a Single P6 Project as a core with various other projects listed in it's WBS. By doing this, you add a new project by extending the WBS - So your new project sits at Level 2 in the WBS. This error is generated when there is a duplicate found in your hierarchy.
Derek Rae
Level 1:
New Friend:
  • Posted on Sep 12, 2014
Derek Rae
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
469
Points
Hi, did you ever find a fix for your error above?
Thanks
tip
Dreamweaver Thought that Teaches You, to search a database with phpmysql...
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from www.interakt.ro its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type.
Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes.
That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php.
Create new recordset in dw like this
SELECT "
FROM table WHERE table.column.you.r.searching LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword.
Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page...
Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply...
So now You have page with results. Test it and see if its working.
If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>.
As for details page recordset it should look like
SELECT *
FROM table
WHERE table.id = 'colname'
create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id']
and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something...
Home I did helped You.
on Jan 21, 2010 • Computers & Internet
tip
How to create a system folder in My Computer System folder like My Document...
How to create a system folder in My Computer System folder like My Document which appears in My computer are special folders which appear can not be deleted. Now if you want to create something like that, a folder which cannot be deleted!!!! . Here is how you do it to create a folder which cannot be deleted!!. It should work both in XP and VISTA.However a word of caution, If you don’t know about registry, either back up or don’t try this. I am not sure how to create a direct script for this so be cautious.
Step 1: Create a Unique Key
Open registry with “regedit” command on run window.
Navigate to HKEY_CLASSES_ROOT\CLSID\. Then right click and create a new key with value as {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Now set the default value of this key to the folder name you want to use. Now your path will look like ( I will call this as parent key throughout the discussion) HKEY_CLASSES_ROOT\CLSID\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Step 2: Add Custom Icon to the folder
Now create a sub key under parent key.
Name it as “DefaultIcon”.
Set the default value of this to the path of the icon image you want to use.
If you dont specify your icon, system will take default icon.
Step 3: Adding attributes
Under parent key create another key with name as “InprocServer32′
Set the default value as “shell32.dll”
Again at the same level create another folder as “ThreadingModel” and set its value as “Apartment”
Same way create another key (under parent level) at the same level with structure as \Shell\My Folder\Command
Set the default value here as “explorer /root,c:\Blog Data”
This has to be same which you gave when you created the first key.
Step 4 Adding Handlers
Under parent key, create another key as \ShellEx\PropertySheetHandlers\ {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Similar way another key is to added to parent key as “Shell Folder”
In this right click and create new binary value called as “Attributes” with value as 00 00 00 00.
Step 5: Settings to place in My Computer
Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
Then to \CurrentVersion\Explorer\MyComputer\NameSpace\
Add the parent key which in this case is {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Thats it, You are done. Try this carefully and I am sure there wont be any problem
on Dec 07, 2009 • Computers & Internet
18helpful
4answers
I can not set up the parent control
Found this from my own research this appears to work (Either way epic failure by Toys R Us who had better issue an apology and provide some sort of compensation for this let down!!).......
I was just able to register and setup parental control from desktop browser after more than 2 hours trying different approaches. I then used that account info to login into tablet and activate controls. Here is what I did step by step.
1. When you try to activate your tablet it open page at this URL: (you might have to restart process couple times - site seems to loose info enetered in previous step)
http://mpf.profiltechnology.fr/wzdinit.aspx?guid=0099FXFX7X00-0&model=TABEO%208&app=darkcafe
You will have to replace guid value 0099FXFX7X00-0 with the actual value of your tabled ID - you should be able to see it in browser address bar.
2. Complete 4 step account setup wizard - in last step when it asks for "Child's firstname" enter unique Id there something like JoeDoe2009 - there seems to be some issues with unique names for app because when I enter my sons name it said it was already taken.
3. After Child's name was registered you will be redirected to payment page - you will have to enter Credit card payment info for $1 transaction (text says that you will be reimbursed for that later).
4. You should see page saying tablet was registered and You should receive email with your Id and password in clear text to email you used for registration.
5. Go back to tabled and tap on MobileParentalFilter icon (one that looks like flower) -- you will see registration wizard again -- on the bottom there is a link saying "ALREADY GOT ACCOUNT" - enter your email ID and password there - you will be taken to parental filter activation on tablet and all should be set.
That's it. Again be ready to restart this process from any point all over again because site is very slow and seems to loose your session.
Having troube with my FOREIGN KEYs on two tables.
I suggest you visit this website you will get the solution, I tried and it worked.
http://bit.ly/1bUVmuW
2helpful
Buick LeSabre 1998. AC on, air flow not going through MID vents.
Sounds like your AC/Heater control unit is bad.the unit is the one you use to switch the air from defrost to vent etc.
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Validation code using single loop for multiple fields in javascript
As example, use it:
JavaScript Form ValidationJavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Form data that typically are checked by a JavaScript could be:
  • has the user left required fields empty?
  • has the user entered a valid e-mail address?
  • has the user entered a valid date?
  • has the user entered text in a numeric field?
Required FieldsThe function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
function validate_required(field,alerttxt)
with (field)
if (value==null||value=="")
alert(alerttxt);return false;
else
return true;
}The entire script, with the HTML form could look something like this:
<html>
<head>
<script type="text/javascript">
with (field)
{alert(alerttxt);return false;}
else {return true}
}function validate_form(thisform)
with (thisform)
if (validate_required(email,"Email must be filled out!")==false)
{email.focus();return false;}
</script>
</head><body>
<form action="submitpage.htm"
onsubmit="return validate_form(this)"
method="post">
Email: <input type="text" name="email" size="30">
<input type="submit" value="Submit">
</form>
</body></html>
E-mail ValidationThe function below checks if the content has the general syntax of an email.
This means that the input data must contain at least an @ sign and a dot (.). Also, the @ must not be the first character of the email address, and the last dot must at least be one character after the @ sign:
function validate_email(field,alerttxt)
with (field)
apos=value.indexOf("@");
dotpos=value.lastIndexOf(".");
if (apos<1||dotpos-apos<2)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
if (validate_email(email,"Not a valid e-mail address!")==false)
</script>
</head><body>
onsubmit="return validate_form(this);"
method="post">
</form>
P.S.: If this information was helpful, please rate this solution.
</body></html>
4helpful
MySQL Auto Increase
Try this -
CREATE TABLE users (
id MEDIUMINT NOT NULL AUTO_INCREMENT,
login TEXT NOT NULL,
password TEXT NOT NULL,
PRIMARY KEY( id )
INSERT INTO users VALUES ( null, 'bob', 'mypassword' );
INSERT INTO users VALUES ( null, 'bill', 'pass' );
INSERT INTO users VALUES ( null, 'sean', '1234' );
Aug 04, 2008 • Sun MySQL
How to compare a value in a subform with parent form's value in Dcount
Assuming that Process id is an integer, this should do the trick:
DCount("[stageid]", "Process Stages", "[Process id] = " & Me.Parent! [Process id])
Regards -- Joe (Access VBA samples)
Top Primavera Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
