Question about OKI C5100n Laser Printer
Full cartridges but says replace them - OKI C5100n Laser Printer
Dear Sir, I full toner cartridge but again and
if u FILLED tone cartridge, then u probably need to replace the little ckt bd on the cartridge that is responsible for telling u it is empty.
if u REPLACED the cartridge, then it may not be installed properly or there is another issue.
Oct 20, 2013 | Office Equipment & Supplies
Samsung CLP-325w says its out of black toner but the toner is full
I have the same problem. It says "End of life, replace with new black toner cartridge-K407 (CLT-K407S)" But I have just replaced the cartridge with a compatible cartridge few weeks ago and havent used it much so it should be almost full. And it was working after I replaced original cartridge with compatible one...Any help???
Oct 15, 2011 | Samsung CLP 300 Laser Printer
Hp photosmart all in one recognizes a full ink cartridge but will not use it
Its showing full but, not printing am I correct?.. Once installed new cartridge printer detects ink level, by chance if cartridge dried up, ink level shows full but it wont print, it might be happened in you case, try to clean the cartridge if not resolved replace the cartridge.Cleaning process you can find out in youtube demos.. do it give life to cartridge..
Sep 27, 2011 | HP Photosmart Premium C309A All-In-One...
Error 1102 appearing
That's usually the sign of two things.
1. Did you reset the ink levels in the maintenance or settings and send them to the printer. If you didn't the printer may now think that the ink has completely run out.
2. It's possible the cartridge has become unseated and the contact circuit strips between the printer head and the cartridge are not making full contact.
Please Rate!!
Nov 25, 2009 | Dell Photo 964 All-In-One InkJet Printer
Maintenance Cartridge Full, Replace Cartridge
reinstall the printer driver again,.
Nov 23, 2009 | Computers & Internet
The printer tells me to replace an ink cartridge because the ink has been depleted. The cartridge is nearly new, though. Just yesterday it showed to be half full. I have cleaned the printheads and the...
There is a chip on your cartridge that communicates with the printer to estimate how much ink is left in the cartridge. When the chip thinks the cartridge is empty it will refuse to print any more pages no matter how much ink is left in the cartridge. These cartridges are only estimated to print "up to 840 4" x 6" photos, or 80 13" x 19" photos." If it showed half full yesterday and then you put through a large print job it is very likely the cartridge is empty. In any case once the chip thinks it's empty the cartridge needs to be replaced.
Nov 09, 2009 | HP Photosmart Pro B9180 InkJet Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Drum full of waste toner
I just replaced the black ink cartridge and now getting the message that drum waste is full replace. What does this mean?
Apr 03, 2009 | Dell 3100cn Laser Printer
Printer will not print.
http://www.fixya.com/support/p169991-brother_mfc_420cn_all_in_one_inkjet See if any of these solutions help
May 17, 2007 | Brother MFC 420CN All-In-One InkJet...
OKI C5100n Laser Printer Logo
23 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Thomas F. Schneider
Ekse
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
