Question about Sharp MX-2700N Color Copier
Sharp mx 2700n factory reset - Sharp MX-2700N Color Copier
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
Anonymous
  • 148 Answers
SOURCE: sharp mx 2700n how to go SP mode and i get error code h5.01
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Posted on Dec 28, 2008
Anonymous
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Sharp MX-2700N how can I clear maintenace code CA?
enter code 20-1 start
Posted on May 27, 2010
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
Sharp mx 2700n tc2 belt day
The second transfer belt is the rubber belt assembly which is inside the right door. The maintenance alert "TK2" indicates that the belt has gone past its' useful life and needs replacement or rebuilding, there is a rebuild kit available.
May 28, 2014 | Sharp MX-2700N Color Copier
Sharp disable fax
Go to administrator setting and change it again to image send.
Dec 10, 2013 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Jan 16, 2009 | Sharp MX-2700N Color Copier
Error code h4-01
Dec 01, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
413 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
