I was in the middle of watching a video when suddenly the screen went black. Well it's almost black, I can barely see just enough to navigate around but it is basically a black screen. If I turn off the monitor then turn it back on or unplug it from the PC then plug it back in, the screen becomes bright and clear for about 1 second before going dark again. I have tried changing the video input to DVI as I have a VGA cable running into a DVI adapter which then goes into the DVI input on the back of the PC. Been using this setup for more than a year now with no problems.
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
My older monitor had a similar problem but instead of black its bright white and it keeps auto adjusting but not right it goes off screen. i still use it just not as a main monitor as it is old. erm see if its it warranty if it isnt then you probably need to get a new one
