How difficult is it to replace a idler pulley. What steps do I take.
You need a serpentine belt tool, you can rent one at the parts place and while you are there get the new idler. You will also need a wrench to fit the bolt. Remove the belt then take the bolt out of the idler and install the new one, you can use some low strength loctite purple to keep this from happening again. Reinstall the belt, return the tool and get your money back for the rental.
SOURCE: Serpentine Belt on a 1999 Ford Escort ZX2
If you have a book picture your are screwed. You do have a tensioner but it is between air con and powersteering pullys. In front from under you can put 15mm wrenchopend with a nother for leverage pull center bolt down to release tension. simple.
SOURCE: 2008 Ford Fusion Wing Mirror Replacement
I checked Ford Focus mirror replacement and it seems to be the same. This is for the manual, unheated mirror.
Remove the mirror cover inside the door - slide a screwdriver behind the cover and pry loose carefully.
Remove the single 10mm bolt and the mirror comes free.
NB. Do not drop the bolt into the door.
SOURCE: how do i remove radio from 2008 ford fusion radio ...
http://www.fitaudio.com/index.php?CategoryID=13
