Question about T-Mobile Sidekick® 3 Cellular Phone
My sidekick3 screen is blank
My sidekick 3 is blank the screen was working until it went blank plzzz helppp mee its just a white screen i took out the battery n reset it like 5 times no help plzzzzzzzz helllpppp
Posted by sidekick3 on
  • 13 more comments
  • GAPeaches Nov 03, 2007
    I've experienced the same problem...It's a shame that you pay so much for a phone and it just goes blank when you use it. I hate that I have relied on the phone as it has all my information on it. How can I resolve this problem?
  • Anonymous Nov 28, 2007
    it just stays white
  • Anonymous Jan 08, 2008
    my screen its white with nothing there i tried 2 reset it an take da battery out plez help
  • Anonymous Mar 20, 2008
    My sidekick 3 screen is blank and is white I have taken the battery out 5 times and still nothing works, anyone know how to fix this?
  • Anonymous Mar 22, 2008
    sreen went balnk 4 nothing
  • Marlii May 08, 2008
    well it is white and everythin else still works its just i cant see nothing what so ever soo helpp..i love this phone but i cant use it when it dont work
  • bigroh Jun 04, 2008
  • GRAMMZ Jun 08, 2008
    MY SCREEN IS BLANK OR THE CONTENTS ARE UPSIDE DOWN
  • RedSoxluver Jul 08, 2008
    My sidekick 3 is working but the screen is blank. when i flip it open it just lights up. what can i do?
  • linnyae Aug 24, 2008
    i dropped it everything works but all i seei\ is a blank white screen. i can hear eveything. just cant see. i took the battery out charged it and reset it. everything. help me !!!
  • NESTOR 13 Aug 29, 2008
    from one day to another my sidekick 3 the screen went blank, you cant see anything, you can hear it but nothing! help!!??
    I've takin out the battery and i rechatged it, but nothing.
  • Anonymous Sep 22, 2008
    If you keep turning on and off it will eventually work again. This last time I think I did it over 50 times but it's finally working again!
  • kikilynch18 Jan 16, 2009
    I have the same problem
    My screen just shows up white or has these lines across it!
    Plz HElp!
  • jrico456 Mar 16, 2009
    IM HAVING A PROBLEM WIT MY SIDEKICK ID I FLIP IT OPEN IT WAS WRKIN FINE THAT I WAS AIMING PPL AND IT JUST WENT BLANK BUT U COULD HEAR PPL WRITING TO U BACK BUT CANT SEE NUTTEN SO IF ANY ONE COULD TELL ME WAT I CAN DO TO SLOVE THIS ILL APPERIATE THIS
  • sophistic8 May 03, 2009
    my cscreen is also white
Terry Fritsch
    President:
  • 625 Answers
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Posted on Mar 23, 2008
  • Terry Fritsch
    Terry Fritsch Jun 04, 2008
    BigRoh-
    Take a look at my fix above
  • Anonymous Oct 27, 2010
    This worked like a jewel, not hard at all-- Thanks a Million!!!
Anonymous
You can also just take out the battery and the sim card.Leave it apart for 24 hours then put it back and it works just as before.
~Ur#1N.E.R.D~
Posted on Apr 08, 2009
Anonymous
Http://www.fixya.com/support/t139207-screen_blank
Posted on Nov 01, 2007
The screen on my T-mobile Sidekick 3 went white.
You need to reseat the LCD cable. More than likely it has come loose in the back of the LCD
Follow the guide at the following link.
Sidekick White Screen Repair Guide
Jun 14, 2010 | T-Mobile Sidekick® 3 Cellular Phone
Screen
Is it white or dark?
If blank white, then the cable needs to be reset if dark then the lcd screen needs to be replaced. They are easy to change and run about 35 dollars for the whole assembly.
Here is a guide for that
Sidekick 3 LCD replacement guide
and here is a link to see what is availble on ebay:
Hope that helps
Dec 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Screen not working
Lisa-
I am sorry to hear that the new sidekick 3 is not working for your son.
Is the screen white, blank, or just hard to see?
If white, then the flex cable needs to be reseated.
How to fix a blank white Screen on a Sidekick
If dark blank, then reseat the lcd assy itself and see if it works
Reseat the Sidekick 3 LCD Screen
If hard to see the screen, then the backlight is dead. A new screen is needed for that.
Replace the Sidekick 3 LCD Screen
I hope that helps
Feel free to contact me if you have questions
Dec 15, 2008 | T-Mobile Sidekick II
My screen is blank
Is the screen white or just dark?
Fix Sidekick White LCD Screen
If it dark or no light at all then
replacement of the Sidekick 3 LCD flip screen.
to buy a sidekick 3 lcd screen look here.
http://www.repairmysidekick.org/Sidekick-LCD-Screens/buy-a-t-mobile-sidekick-3-lcd
Look for one that has the torx screwdriver included
Jul 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
HELP SIDEKICK 3 WHITE SCREEN!!PLZ
Follow this procedure and it should fix the issue. If not then a new lcd definetly will
if you don't have a t6 torx driver, a small flathead will do the trick.
May 23, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Blank Screen???
Is it white or just black?
If it it is white then this procedure should fix it, Fix Sidekick White LCD Screen
if it is black then a new lcd is in order. They run about 45 dollars and fairly simple to install.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
May 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick id
Is the screen white or black?
If it is white you may be able to fix it, black maybe not.
The following instruction for a sidekick 3 but it is the same for a sidekick ID. Just reseat your lcd instead of installing a new one.
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 white screen
Did you by chance drop the phone recently?
A loose cable for the lcd can cause this or a bad lcd.
You need to disassemble it to take a look.
Sidekick 3 Disassembly
You will need a set of Torx screwdrivers to get it open.
Nov 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
1,769 people viewed this question
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Rob Hill
Rob Hill
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
