TRUTECH/DAEWOO DVD RECORDER/VCR DRT-S810
NO POWER, ONLY GREEN LED STAYS ON BERALY. CHECK AC VOLTS OK. CHECK DCV NOT READING CORRECTLY. STILL PUSH POWER TO SEE IF IT TURNS ON NO POWER. PLEASE HELP. GIMBLIET
Anonymous
  • 790 Answers
Hi!
did you check the +5 volts if exactly? and the +9voltsif exactly? now if you got over voltages in the said voltages you got abnormal power oscillation! or did you check the regulator? maybe the ADJUST Pin is in abnormal function! and try to unload the power board then you can test run the power board by checking the voltages in secondary.
Posted on Nov 07, 2007
Need a download owners manual for TRUTECH CVR/VCR DRT-S810
https://www.2instructions.com/search.php?cmarque=TRUTECH&modele=DRT-S810 Hope that helps.
Jul 26, 2010 | TruTech Televison & Video
Vcr/dvd burner combo
You will have to go into the dvd menu and finalize the disc for it to play on any other player. Check in your manual for more information.
Mar 17, 2008 | Zenith DVR413 DVD Recorder/VCR
Can't put a VHS in
If the VHS isnt going in it may require a little force as the track might have gotten stuck with dust. if you think its something else i suggest you openj it up and see if these is anything logged in the carriage way or if the tray might just be stuck. once it is open simply insertthe vhs tape and keep pressing in on it until the machine takes it in. while pressing keep you eye on the carriage and see hwat might be stuck as to preven the tape from entering. BUT I THINK IT MIGHT JUST REQUIRE A LITTLE FORCE as it may be binded with lack of use
Jan 04, 2008 | Televison & Video
Trutech DRT-S810 Does not power on
known issue with this unit. The power supply used in this unit is below quality and is often the cause of power not getting to rest of the unit. The company is from china and does not have a usa warranty service since they operate under the daewoo umbrella.
Dec 29, 2007 | Zenith DVR413 DVD Recorder/VCR
TRUTECH/DAEWOO DRT-S810 NO POWER TO PCD RF-IF BOARD
The power supply needs to be changed. Not sure how you could do that since this item is from china and I could not find parts for this unit.
Nov 14, 2007 | Televison & Video
I need a remote
You need to contact "Daewoo/Trutech" directly to get a replacement.  Good luck they are not easy to get a hold of.
Buy a universal remote.  Check the booklet to see if your model is listed before buying it.  This is your easiest way.
Oct 27, 2007 | Televison & Video
MODEL#DRT-S810 DVD RECORDER/VCR COMBO
The DVD recorder is like a PC internal drive. Pull the 4 pin molex connector and check the voltages across 1&3, 2&4. Should have a (+ or -) 5volt, and (+ or -) 12volt (you can compare with a PC's voltage across the same kind of connector if you want). If you don't have a 5 & 12 volt reading your power supply is probably bad. Optionally confirm DVD recorder works by removing and attaching to a (spare?) PC.
Televison & Video Logo
490 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
