Question about Andis Styliner SLII Hair Trimmer
I took apart the blades of my Andis Styliner II Model SL II and now its loud
Posted by chioke on
Anonymous
GET A ******* LIFE AND A NEW BARBER *****
Posted on Jul 12, 2009
  • Anonymous Jul 12, 2009
    GFNFJGFRHJGFHRNDGMHEBJOPBIJEIOPBGEJKLVNSJKLFNASJKVNSJK VJKVSJKSJKLVNJVN DJKD JK DK DFJKBVKLVKL RGJNE90NE[0IENHEO[INRIORO MDOEROVMOMXCOMSDFOMVOMJ ***[BJEO[IBJOIN E[OIBAKOM IOVOERIEOBIMBO[INBE[IONB[OBNE[IOPEJG0WEGJK30GJE30GJEOBNIBIOERJGINHOJ'P
  • Mikepug315 Mar 12, 2012
    I cant stand pple like ree114 good advice u fkn prik . If he ever sat In my chair hee wud end upwith a bald spot or with no hair at all. Anyway u must have not tightned everythng back up snug if theirs a rattle or if it got loud
Andis Styliner 2 is not cutting it slightly pulls the hair
This styliner is crapt. I buy new clipper, right out of the box it doesn't cut, put a new blade on it, same thing. It doesn't matter how you adjust the blade, it does not give sharp line, and hard to do shape up. Andis Sucks.
Nov 13, 2012 | Andis Styliner SLII Hair Trimmer
I took apart my andis hair clippers and now i can not get the little blade to stay in place is there a trick to this?
i took apart my andis t-outliner & i dont know where to put the oval shape silver pice
May 20, 2010 | Andis 04603 Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
How do i get blades closer on the pivot pro t liners
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
Oct 04, 2009 | Andis T-Outliner Hair Trimmer
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Replaced with new blades, and now not cutting
 The protective film is still on the blades.( spray with clipper cleaner while running the clippers) Or there's a hair between the blades.......same fix
Mar 18, 2009 | Andis Styliner SLII Hair Trimmer
Andis Styliner SLII Hair Trimmer Logo
569 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
