"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
Also, on a propane heater, some makes & models will have the gas valve 'Lock Out'. This will be done by the ignition control module. To reset, heater will need to be powered off, then back on.
Good Luck - hope this helped.
SOURCE: hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
