Cars & Trucks Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scenic o2 doing same didnt give me chance to re enter code
After putting in the wrong code it let me re enter only 1 number the radio and cd came on but beeps every few seconds it wont let me try to enter code again will renault tell me my code cos i think i must have it wrote down wrong
Colin Stickland
Level 3:
  • Renault Master 22,516 Answers
  • Posted on Jun 09, 2009
Colin Stickland
Renault Master
Level 3:
Answers
22516
Questions
Helped
6997499
Points
66324
Put a new one in with sd card and usb facility and dump the renault one.please dont start me off with renault electrics again and their encrypted software.
2answers
Help me how to unlock my code for my Renault Megane Scenic 2001 CD player. Model no: 22DC279/62P
you shold have the number in your owners handbook if not you can go to main dealer with v5 log book and id licence etc they will give you the code it may cost 10 pound
5helpful
3answers
Put wrong code in renault car radio now got error message . How do i clear this message to put correct code in ?
If you take the earth lead off the car battery and leave for about 2 0minits then reconect the battery it should reset the radio so that you
can put in the right code.I hope this was helpful and done the trick.
Disc 2 Alpine radio ask for code ,Do have code but radio does not allow to enter code
Leave the radio on, until it displays the word "CODE".
then you can enter the code using numbers 1 to 4.
The time until "CODE" is displayed depends on the number of previous wrong entries. 1 minute for one wrong entry, 2 hours for 5 wrong entries.
Just put the radio on and leave it that way until it says "CODE"
How do i install a new radio
The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel surrounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easily. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your vehicle in a safe place and leave the radio on for about 1 hour (no engine running just click the ignition switch to operate the radio). After one hour, the radio resets and will ask you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the CD button and there you have it.
Hi i am having trouble finding out my radio code for a 2000 renault scenic, can anyone help!!!!!! serial number is RN259F10313582 7700 434 424 77004344247X632
Go to www.instant radio code.co.uk
It will cost £8 but will show how to enter code etc
Have you tried your local renault dealer,give them your vehicle vin number,they might give it to you for nothing
6helpful
3answers
2001 mitsubsi eclipse enter car radio wrong code 3 times
call 1888mitsu2001, choose option #4, then hit * (star). give the operator the last 8 numbers in your vin and they will provide the radio code for FREE!
DO NOT PAY FOR THE CODE ONLINE OR GO TO THE DEALER (they will also charge you).
- you will also need to provide the serial and part number of your radio (takes about 5 minutes to take apart an eclipse dash...1 screw in the bottom of the HVAC panel) if you call the 1888mitsu2001 it will provide basic instructions on how to accomplish this.
- if your radio says "off" (meaning you entered the wrong code too many times) you need to put your key in the ignition and turn it to ACC mode for approx. 45min - 1hr and then your radio will say "code" at which point you can enter the code to unlock the radio.
7helpful
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
32helpful
10answers
My renault scenic radio says code i am unable to enter the digits for the code
Hi - the way to enable code mode is to turn off the radio - then hold down 2&5 & press the on button - this will bring you into the 0000 code mode.
Regards Paul
2answers
Cd player is in off made after I put the wrong code in 3 times
Here is the answer to the best of my knowledge. This applies to any body that has the need to get the code from the dealership and requires to pull out the radio and look up the serial number. The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel sorounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easyly. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your veichle in a safe place and leave the radio on for about 1 hour (no engine running just click the ignition switch to operate the radio). After one hour, the radio resetes and will aks you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the cd button and there you have it. I hope this helps.
33helpful
6answers
Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
john h
Are you a Renault Expert? Answer questions, earn points and help others
