How Do I Import A File on My computer it wont work
I tried everything to downloading the software again, and again, and again. Also T deleted My device Driver and installed it again, and i still can't get my files on my computer.
Re: How Do I Import A File on My computer it wont work
Did you download the correct drivers for your Jazz DV-179. The drivers for different models and different operating systems are different. Try again for you medel and OS.
If it says to restart, then restart the computer. If that doesn't work try uninstalling and reinstalling the program again. Sometimes installers can be corrupted.
1. try to download it from a different server 2. try to save the file in a different location in your computer, say the desktop (you can move it from there later.) 3. try to save the file in your computer with a different name.
if none of the above work - clear all the temp files in your computer and try again.
to clear the temp files:
go to Start - Run and type in %temp% in the "Run" box and click "Ok" now select everything in that window and delete it. restart your computer and try step 1 thru 3 again.
best way to recover any file is by using recovery software, but you must act quickly before that file will gone forever because everything that you do, installing, downloading anything you do can make this file lost forever, my best recommendation is this data recovery which helped me before http://www.asoftech.com/adr/
Well, more details are needed here.
But to start, uninstall any scaning software you got. Then install the Software package from the HP website.
Then try again using this software and be sure to follow the step by step installation on the screen.
If you have photoshop installed or some smiliar software, you could try to use the Acquire/Import from TWAIN option... should be in the file menu somewhere. This will try to import your scan in photoshop or your software directly.
If it's still not working, give us more information about what happens, what you did to solve your problem so far.
use the windows 2000 professional cd to install the windows again, you can install it to another folder so you get to keep your files if you decide to do it this way, ones your computer is working again, make sure you delete the downloaded file, if you start the file again, the one with the virus, you will have todo this all over again.
