To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
It sounds like a panel fault. Anyway, check this link. It has details with illustrations to Plasma display panels. Check them to that of your TVs, and make sure. http://electronicshelponline.blogspot.com/Pull up previous posts there, either by its left side bar,
or view it in Timslide option.
If it is not a setting problems, and if the black and white is only on LCD and not on picture, then it is a problem with the LCD. Probably just the ribbon cable not well inserted into the connector. Camera must be taken apart to fix this problem. Better to have the job done by a technician at a camera repair shop.
Do you have a led or crt display? It could be just your display settings. Go to control panel /display properties /setting tab / and try changing the screen resolution. If no difference try the color quality. You can change the color bits without hurting any thing. Just remember what you changed it from and to.
If this doesn't help maybe you'll need a new screen.
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says.
"You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
