Question about Dirt Devil M086700 Vision Bagless Upright Vacuum
Dirt devil vacuum is screaming loud and barely picking up. Ear plugs did not help.Just replaced a broken belt.
Posted by in78on on
Anonymous
    Problem Solver:
  • 8 Answers
You need a new motor or a new machine that is unfixable
Posted on Jun 12, 2009
Brush roller won't turn
Hey, this is Jeremy with Crucial Vacuum,
There are 2 potential reasons as to why your Dirt Devil AccuCharge roller brush is not working:
1) The roller brush may be blocked by debris that was picked up by the vacuum. To remove the blockage, switch your vacuum 'OFF' and unplug before proceeding. Then, lay the vacuum down and try to remove anything that is lodged in the roller brush.
2) If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace if needed.
You can purchase replacement parts for Dirt Devil direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 26, 2015 | Dirt Devil AccuCharge 15.6-Volt Cordless...
Hi I have a dirt devil vision. Hose works, but does not vacuuming the floor. Belts are not broken. Larger belt is moving, smaller belt that moves the brushes does not.
hi krueger, sorry for the problems but hers an idea how about turning on the vacuum and put your hand under the part where it sucks uo the dirt off the floor and i guessing you would have a little suction, since the brushes are not moving its going to not pick up as well as it should my guess is that the belts need to be replaced even if one is moving, i would change both belt to be sure and also are you smelling a burning smell if so then that would prove fact to needing new belts, hope this helps, Jamie
Dec 14, 2012 | Dirt Devil M086700 Vision Bagless Upright...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Dirt Devil FeatherLite Belt
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The hand cleaner picks up dirt but the floor cleaner does not.
A couple ideas.
1. Have you emptied your dirt?
2. Are your filters clean?
3. Is your roller brush working and if not, is your belt broken?
Hope this helps and good luck!
Mar 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Turns on but does not want pick up anything.Suction is good but the garbage does not go into cannister.
The reason it is not picking up is because the belt is stretched or worn. You simply need to replace the belt. you can get belts here:
Dirt Devil Belts
Feb 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuum making loud noise
It could be 1 of 3 things:
1. The belt2_bing.gif that drives the beater bar. (Inexpensive)
2. An impeller that has a broken wing or 2, throwing it off balance. (Expensive)
3. Or, the bearings in the motor are going out. (Expensive)
Hope this helps,
Jim
Nov 27, 2009 | Dirt Devil Featherlight Bagless Upright...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Dirt Devil M086700 Vision Bagless Upright Vacuum Logo
730 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
