Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
Need owners manual for a mikita miter saw LS1013 to replace cover spring
Posted by percies on
Anonymous
  • 2,176 Answers
Go to Makitatools.com and on the right side type in your model number and it will take you to a page where you can get the manual or the breakdown. Let me know if I can help further, I work on them everyday/
Posted on Jun 13, 2009
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Can I bypass (hotwire) the controller on my Makita ls1013 Miter saw?
Not a good idea. Miter saw are too dangerous to be altering them in any way.
We need an op-erating manual for Makita miter saw, Model LS1013. Where can we find it?
Cut and paste the following link into your browser search bar, and you will be taken to the page that you need to get started:
http://www.makita.com/en-us/Modules/Search/Default.aspx?Param=ls1013
Then click on the appropriate full model number and you will next see links for the parts breakdown and manual for your saw.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck, and please provide feedback if this helps!
How do i unlock a mikita miter saw ls1030n. i cannot lift the blade so i can use the saw.
should be a nob on back on motor side of saw that pulls out just a bit some times u hav to push down on saw to get it to pull out then let up on saw
How do I remove the threaded rod from beneath the turn table of a Mikita LS1013 Slide Compound Mitre Saw ? I have removed the two black turning/tightning handles but cannot see how the rod is removed.
if you removed the handle from the rod you would need to put a pair of pliers on it gently and remove it. or if you turn it upside down and remove the tube from sliding mechanism you can grip the rod from there and unscrew
8helpful
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
1helpful
How to lift blade on mikita 10 mitch saw
right side of saw is a spring loaded knob. push saw down and pull out knob - rotate knob 90 degrees.
2helpful
2answers
Makita LS1013FL manual missing
Yes go to Makitausa.com and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Top Makita Saws Experts
David Shaub
Marvin
Marvin
Narseman
Are you a Makita Saw Expert? Answer questions, earn points and help others
