Question about Audiovox FPE3206 32 in. LCD Television
No picture when turned on
Has power, no picture shows on screeen
Looking to understand the problem with my samsung tv no picture but sound; images are very faint but you can see them if you look close
show flashlight towards screeen if you see picture then your backlight fuse must have blown... needs repair
I am asking about my laptop problem when i turn the power on. after 10 secs.my laptop turn off without showing anything on lcd screeen..hoping for your response ..thanks a lot
it sounds like you are having a heat problem. Check the vents on the side and it is blowing air if not the fan might not be working, If it is under warranty call were you got it and they will help you.
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps you out.
BuddyMc
Turns on with sound but the picture is running colors mostly see red and blue also double vision. 3 colored lines show up on screeen when first turn on
do you have the convergence option in the customer setup menu? is the picture convcave bowed in at top and bottom. if you dont have the convergence option you might have the fl231 fuse problem. or something simular. first read this to determine if you do. if you dont you might have still have a convegence issue http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know i am here to help.
Camera will not show image on screeen or in veiw finder. Green status light is on.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
2answers
My proview 700p has lines and picture jumps can anybody help me please
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Screen has no picture
Screen lights slow blinking than hardware may not supported to your laptop config so try to install branded screeen for your laptop availalbe at service centre.
THNX
2answers
Screen only shows "access"
One of my friends has the same problem with her camera, but we can't even get old pictures to come up on the screeen. When you turn it on it says access for about 15 seconds, then tells you to tell the camera off and then back on.
Audiovox FPE3206 32 in. LCD Television Logo
Top Audiovox Televison & Video Experts
Ekse
Raj Patel
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
