Have a 3 prong plug washer/dryer but a 4 prong outlet need an adapter. outlet size [14-30R. 30A-125/250V
SOURCE: used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
SOURCE: kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
SOURCE: Kenmore Washer/Dryer Combo Unit Cord Issue
Click here for more info on the electrical connections from a 3 to prong.
I would suggest to check with the superintendent of the building first before hooking the appliance. That way you will know if the wiring will be able to handle the amount of power require to operate the appliance.
SOURCE: I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
