Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
My cls 1110 walkie is stuck on channel 1, how can i change it?
No matter what i do i cant get the channel to change from 1, any solutions?
Posted by shythappens2 on
eradiostore
  • Motorola Master
  • 1,667 Answers
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Posted on Jun 10, 2009
Wont charge
Contact Motorola Solutions Support
portal motorolasolutions com
Mark
Motorola Mobility Support
1helpful
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
How to change frequency on motorola cls 1110
Here's a link to the user guide https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiC0sze6uLJAhVGZCYKHZXPAzsQFggzMAE&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_electronics%2Fdoc71%2F71607.pdf&usg=AFQjCNH713XET4rJahFjWGFIU0-PFW21vA&cad=rja
2answers
I have two motorola cls 1110 walkie talkies that are not working and flash r 13 and F 8.
In testing we have been unable to duplcate your flash r13 F8. You might try restoring the factory settings by holding the PTT and the MENU button in for 3 seconds while turning the radio ON. (You will need to do this to all your CLS1110 radios in order for them all to match.)
If this doesn't clear the problem, then try swapping the battery with a known good radio and see if it solves the issue. If so, you need a new rechargeable battery pack.
If resetting the radio and / or changing the battery does not solve the problem then your radio likely needs replaced. Schematics and parts were never made available for this model.
Best regards.
What channel is 467.5625 on mymotorola cls 1110
Here is a link to the user guide for the CLS1110: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf The freq chart is on page 39.
Sorry to let you know 467.5625 is not one of the frequencies.
Best regards.
2helpful
When I tried to change the frequency on my Motorola CLS 1110, I see a lock graphic. How can I get rid of the lock so I can change the frequency. Right now it has only 1 and 2 frequency and I need 4. Thank...
To unlock (or lock) your keypad hold the menu button in for 3 seconds.
Here is a link to the user guide. The CLS1110 is a 1 channel radio. It has several frequencies built in to choose from.
My motorola cls 1110 is frozen and the screen says f 8
Here is a link to the user guide. Your radio is a one channel radio, and the F8 indicates it is set to frequency number eight.
1helpful
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
