Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Keep turning off
SOURCE: A2 error on Bosch tankless water heater
Posted on Jan 23, 2009
SOURCE: Bosch Pro tankless water heater overheating
The vent pipe you use is the correct size for the heater.Longer runs require bigger pipe.I also would check to see if the water is getting to hot.
Posted on Mar 16, 2009
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Posted on May 06, 2009
SOURCE: i have a 250SX aquastar bosch tankless hot water
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Posted on Apr 11, 2010
SOURCE: Bosch Tankless water heater. model AQ 250 SX
Error codes F1 and F2 do not show among common error codes.
Call Bosch 1-800-642-3111
Before calling service technician, open following links for Bosch troubleshoot resources:
Error codes are considered start-point for troubleshoot.
Multiple error codes can indicate PC board failure.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/Troubleshoot/tabid/569/Default.aspx
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Posted on Aug 11, 2011
