Question about Sony Cyber-Shot DSC-S90 Digital Camera
Cyber shot can view pictures but will not turn on
Will not turn on
5 Related Answers
Anonymous
SOURCE: Sony cyber-shot DSC-S500
If you open the camera up, whick I know is an intricate task, and take the screen down but don't unplug it, at the right bottom their is something that resembles a watch battery, if you can figure out how to get it off and find a replacement it will be fixed... This battery serves a a sort of memory power, even though you have batteries, this battery keeps the memory for the camera's software, so inturn without it the camera is dead in the water. this is fixable!
Posted on Feb 05, 2008
Anonymous
  • 10594 Answers
SOURCE: Sony Cyber Shot DSC U60 - black screen
Your camera has defective CCD Imager and needs to replace. Good news for you, Sony will replace this part free of cost. Follow the Sony weblink for further details.
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Posted on Jul 24, 2008
Anonymous
SOURCE: The only functioning modes are the picture viewing & set up modes
Have Sony DSC-P73 with exact problem. Only turns on in SETUP mode and when switches to all other modes camera shuts off usually with lens extended. Have tried new batteries - new memory stick - new everything and nothing helped. I just took out the batteries and attached the AC ADAPTER and all works perfectly now so problem is with either batteries - battery compartment or battery connections. As long as you do not need a "PORTABLE" camera, using AC Adapter solves this problem :)
Posted on Mar 25, 2009
Anonymous
  • 691 Answers
SOURCE: My sony cyber shot camera does not work it turn on
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 01, 2009
Anonymous
  • 85 Answers
SOURCE: Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Posted on Apr 17, 2010
Hi, my Cyber-shot DSC-H55 is displaying System Error C:32:01 everytime I try to view pictures that have been taken. This happens only when I try to view pictures taken and I have to turn off the camera in...
for all those who c.32.01 error is an error related to contacts camera card reading virtually fail to read the card. for this problem must disassemble the camera and exert a little pressure on each contact then to reinsert the card and restart the camera
1helpful
I have a sony cyber shot DSC-S700 camera, I can take photos but when I want to download them on my pc there is no photos there to view but I still can view them on the camera itself
Pictures are saved into folders on the camera - 101, 102, 103, etc. When accessing the camera from the computer, be sure you are looking in the folder on the camera where the pictures are.
Sony Cyber-Shot DSC-P72
It could be that the battery isn't holding a charge anymore if you are using rechargeable batteries in you camera. Most of them have a short life to them. If you can get a hold of another one, see if that solves that problem.
2answers
Cyber Shot DSC-S700
VGA 640x480 is the smallest you can set the camera to.
Accessing pictures on memory stick
Dear LisaLu,
If the file extention of picture i.e JPGE has been changed, camera wont show that picture.
You should paste those pictures in same folder of cyber-shot.
5helpful
File Error
my camara when I see or viewed the picture same of they are bad with lines and same videos says error and I can't see it
Cyber shot viewer
check your memory card if its loose....
Sony Cyber-Shot DSC-S40 won't take pics
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Sony Cyber-Shot DSC-S90 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
Rehan Zafar
Rehan Zafar
Are you a Sony Camera Expert? Answer questions, earn points and help others
