Question about Whirlwind FH-778 Air Conditioner
I have a Carrier 4 ton unit model number 661CJ048-A which is charged with R-22 capacity is 9,25lbs. It has developed a leak at the evaporator coil. It has rust on the coils which from what I understand means the leak is there. Now currently it has only 3.25 lbs of R-22 left in it. I want to replaced the coil, but until I do I want to replace the R22 with R-134A, and be able to use the AC unit, until I can afford to puchase the coil, which I found one for $720 from a company in Florida. Do I need to empty the R-22 before recharging with the R-134A. Or can I mix the 2 of them together. Since I have ordered the R-134A and it contains 30lbs I figure I have enough to re-fill the system twice. The final question is the High Line & Low Line, the High Line is the smaller of the 2 lines? I am not a HVAC trained tech, But I am an Engineer who spent 20 years as a field engineer supporting many devices. I do know how to soldier and rebuild equipment. Not to mention I understand the fact that you don't soldier with any Freon in the system. I am in the Dallas area, and the reason I am going through all of this I was laid off back in December and can't afford the rates from a HVAC tech.
Posted by frank_verea on
  • 1 more comment
  • Ken Bledsoe May 11, 2010
    What you are talking about would cost you more in the long run then just the A coil. R134a uses a different oil. So you could ruin the compressor. I would highly recommend not doing it. Might have to buy a used window unit to get you by and 720 for a coil is that installed by a tech? If you can located the leak in the a coil have it brazed and recharged. If you can see the leak area. Would be alot easier. just my feeling towards your problem. Ken here in Kansas
  • ed rodgers Aug 06, 2013
    bullsh*t haha r134a wont carry the oil but there will be enough r22 to do the job and it will increase pressure to about -31 making system more efficient .. ive mixed them for years then refitted and recharged with no damage at all to system ..only a/c tech will tell you no ... uh, go figure
    i ran a central a/c unit half and half for over 4 years no problemo ... lol gas is gas people only the oil changes and the boiling points ... as long as theres still enough r22 to carry the oil what damage will be done to compressor ??? duh ever watched a tech ad oil ? it aint exact science
Anonymous
  • 614 Answers
First your system is 22 and 134A is a auto AC refrigerant. I have never seen it used in residential ac. I have been in AC business for 45 years. The new refrigerant is 410A or Puron. But you can not use it. Your outside unit is set up for 22. Mix 134A with the oil used in a 22 system is not done. You need to get the correct coil for your system. They are going to make 22 for years. They now have a Drop in for 22 called NU22. I know times are tough but you may have to get a Service Tech anyway.
Posted on Jun 09, 2009
1 Related Answer
Anonymous
  • 158 Answers
SOURCE: R-22 vs R-134A
not a good idea to swap gas coz need to change tx valve and flush system and use polyester oil,cost a lot. ur best options is to repair, pretty sure it can be soldered
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 30, 2017 | Bryant Heating & Cooling
Comfortmaker
need more info on condenser itself the model number not coming up but the nomenclature u gave looks to be a 4 ton unit. why I say that is the 48 normally represents the btu's 12000 btu per ton. so 48 represents 48000 btu 4 ton. now this depends on your house 400 square feet per ton is a rule of thumb without doing a proper house inspection. how many windows type of windows all kind of stuff. so 4 ton is roughly good for a 1600 square foot house depending on all kinds of variables. if I can get a full model even if it shows ----00-- something like that I can give you a for sure answer. u may even get an r-22 unit which u can buy only as a dry unit companys still make them but can no longer ship them with r-22 in the they come charged with nitrogen which will save you a few grand on install because you don't have to change the indoor coil to a proper sized 410 a coil or the lineset. be aware of contractors who tell u to keep the indoor coil they will add a expansion valve and flush the lines with r-11 or rx-11 flush u wont get the efficiency or 100 percent working condition of a mix mash system.
Oct 20, 2013 | Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
Determining the age and size of a Trane evaporator Model # TXH054A4HPAF
The serial number on that evaporator will have the date code in it, the model will tell the capacity (size). It looks like it is a 4 and a half ton or 54,000 BTU coil and has a TXV valve to meter the refrigerant.
Jun 16, 2011 | Ruud UAKA037 Air Conditioner
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
R-22 vs R-134A
Jun 09, 2009 | Heating & Cooling
Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
May 09, 2009 | Carrier Heating & Cooling
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Carrier evaporator coil
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
358 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Paul Carew
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
