Continue to lose the auto transmission and lights/gauges go crazy. Dealer has already replaced Power Train control module (covered) and two other control modules ($1300). Just got car back from 2nd visit and $1300 and doing same thing again. What could be causing this? Obviously the dealer doesn't seem to be getting it!
SOURCE: ABS light comes ON. Dealer recommends replacing ABS module
i found a site that will rebuild your old one for $300 ... modulemaster.com......................................ebay has used one $ 200 hope this helps
SOURCE: transmission control module needs replacing
The transmission control module is mounted outside of the transmission. The location is under the dash assembly,driverside. Right now, Kia would be the only supplier for this module. I'm not aware of any aftermarket TCM or rebuilds that are available. You can get a factory TCM from an auto salvage yard and save a lot of money and it will be a factory part.
SOURCE: eds skid control activates for no reason.
The problem may be an intermittent problem with one of the wheel speed sensors, if one wheel speed data recieved by the ECU does not match the other 3 sensors the ECU will interpret that as a wheel slip or spin, this will cause the ECU to initiate the traction control.
SOURCE: i have a 2006 pontiac
You may need a more sophisticated scan tool for this type of analysis. Take it to a deal er or reputable mechanic who has such a tool. Without it, it can get very expensive with trial and error.
SOURCE: modules for golf 1
Check the fault codes Sensors that are faulty such as the crank position sensor will not allow any spark where you describe.
The
following are the general instructions on the start of diagnosing any
electronically controlled engine or transmission problem.
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully electronically
controlled by a computer called the PCM and TCM (Power Train Control
Module, Transmission Control Module). When a problem like this or
other drive-ability related problems occurs the computer stores a
record of the problem (there are of course some exceptions to this,
like the fuel pump, engine coolant temperature sensor and MAF sensor
for instance) in the form of a fault code in its memory, to read
these fault codes you must have the systems memory scanned with a
special tool. Once the fault code(s) are read you then must perform
the appropriate diagnostic testing to find and resolve the problem(s)
DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED
THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT
MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for
correct spec for your make and engine type.
Also engine mechanical problems ca cause many drive-ability related
problem such as rough idle and other symptoms
Hello
The
The
The
The
Hello
The
electronically controlled by a computer called the PCM and TCM (Power
Train Control Module, Transmission Control Module). When a problem
like this or other drive-ability related problems occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump, engine coolant temperature sensor and
MAF sensor for instance) in the form of a fault code in its memory,
to read these fault codes you must have the systems memory scanned
with a special tool. Once the fault code(s) are read you then must
perform the appropriate diagnostic testing to find and resolve the
problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED
TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD
EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always
check fuel pressure for correct spec for your make and engine type.
Hello
The
Hello
The engine
and automatic transmission in this vehicles drive train
are fully electronically controlled by a computer called the PCM
(Power Train Control Module). Whenever a problem like this or other
drive-ability related problems occurs the computer stores a record of
the problem (there are of course some exceptions to this, like the
fuel pump, engine coolant temperature sensor and MAF sensor for
instance) in the form of a fault code in its memory, to read these
fault codes you must have the systems memory scanned with a special
tool. Once the fault code(s) are read you then must perform the
Hello
The engine
and transmission in this cars drive train are fully
electronically controlled by a computer called the PCM (Power Train
Control Module). Whenever a problem like this occurs the computer
to this, like the fuel pump, engine coolant temperature sensor and MAF
sensor for instance) in the form of a fault code in its memory, to
read these fault codes you must have the systems memory scanned with
a special tool. Once the fault code(s) are read you then must perform
DO NOT REPLACE ANY PARTS UNTIL THE DIAGNOSIS & TESTING IS
COMPLETED.
Based on my 25 years as a Ford dealer tech I tend to think the final result will be a new transmission is needed.
