Question about Refrigerators
In side by side whirlpool refrigerator freezer ice cubes stick
In side by side whirlpool refrigerator freezer ice cubes freeze together into large chunks (small glaciers) difficult to remove.
Posted by jack_ridgewa on
Anonymous
  • 149 Answers
If they are hollow and stuck together then u are not getting enough water..check the supply.
Posted on Jun 11, 2009
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice sticks together
the ice cubes stick together because the water level in the tray is to high and the cubes can not be separated so turn the valve on the wall behind the unit closed some to lessen the amount of water in the tray
Apr 05, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
I have hollow icecubes too, and water from the un frozen icecubes spills in bin and all the other cubes stick together. IS There Not a way to adjust the timer on the icemake to turn slower so they will...
your hollow cubes tells me your ice-mkr is not receiving enough water. first check water supply. does your refrig. have a water filter? also you could have a bad/restricted water valve.
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
398 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
