RCA 25201RE1 Corded Phone Logo
Question about RCA 25201RE1 Corded Phone
2 fax machines on 1 line
I have 2 fax machine sharing 1 line. When faxing from fax machine#1, it is received on fax machine #2 and visa versa. What can I do to eliminate this problem?
Posted by mabel_mullen on
Anonymous
    New Friend:
A "barge-in protection" device obviates the need to shut down one fax machine at a time; basically, the device locks out any other devices from accessing the line after the first device goes online. So, if you're sending a fax, or if you're receiving a fax, the second machine can't "barge in." Google "barge-in protection" for product hits.
Posted on Nov 11, 2009
Anonymous
    Champion:
  • 211 Answers
Once you place your both fax machine on same line you will keep getting this issue. Fax machine is waiting for a fax ring signal that your other machine is sending. Shut down one machine when faxing or connect your alt fax machine to a different number this way you can send faxes when need to.
Posted on Jun 09, 2009
  • Charlene Wittman Jul 25, 2013
    This explains 'why' I have the problem but it doesn't address how to get rid of the busy signal. I unplugged both units but can't stop the busy signal!!
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
I have 1 phone line that is shared with my all-in-one fax, therefore, we are using the phone/fax in DRPD mode but I am unable to receive incoming faxes. The fax machine is a Samsung SCX-4521F.
I would get a line sharing device. That device will be able to establish wether the inbound call is a fax or voice call, and route it accordingly.
Having trouble receiving faxes, takes several times of someone sending to me to receive.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Stand-alone fax machine share the line of a business extension?
Only for outgoing faxes. You would need fax server software to receive
Phillips magic 3 fax machine
THE DISPLAY READS 'EXTERNAL 'PHONE'
THE PHONE LINE IS SHARED BY MAGIC 3 AND BROADBAND.
1.USING THE PHONE INTERUPTS THE BROADBAND
2. THE TIME AND DATE DISPLAY DO NOT DISPLAY UNTIL THE RECEIVER IS PICKED UP.
3. ANY SOLUTIONS?
1helpful
2answers
Faxing
To fix this issue I would need some more information,
1. Is it a dedicated phone line Or sharing phone line?
2. If it is a sharing phone line then do you share it with an answering machine or a voice mail?
3.If it is an aswring machine or voicemail.. then how many rings has it set to answer?
How do I set up my X7170 to receive a FAX?
Link
Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
To set a number of rings for the automatic answering mode:
  1. On the control panel, press Mode repeatedly until Fax is selected.
  2. Press Options until ANSWER FAX WHEN appears.
  3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
  4. Press Select.
  5. Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
  1. Make sure the All-In-One Auto Answer light is off.
  2. Press *9* on the telephone after you answer the telephone and hear fax tones.
  3. Hang up the telephone.
The All-In-One receives your fax.
Answering machine Recommended for a shared fax and telephone line
To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
  3. Press + until After 5 rings appears.
  4. Press Select.
When a ring is detected, the answering machine picks up the call.
  • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
  • If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
Top RCA Lands Phones Experts
Marvin
Marvin
ray gallant
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
