Question about Brother DCP-110C All-In-One InkJet Printer
Scanner cover open
Cover is closed but display keeps asking to close cover, help can it be reset with a code like ive done on the error 46 ...
Posted by jabbaman on
Mix-it-up
  • 832 Answers
Simply force the button front into position by pressing it with both hands.
In case your wont be successfull stick a thick tape at he position were the cover switch contacts the inner cover (opposite to the display towrds inward is a double plastic contact).
Posted on Oct 28, 2007
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Canon MP530 error code - "Check Printer 6500"
Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error code 50C
Hi there Error 50c
This is for the Dell 940 but may do for yours aswell.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 07, 2010 | Dell A960 All-In-One InkJet Printer
Printer will not print it will say error 50c
Hi there Error 50c
Ok try this.
color cartridge.
Sep 18, 2009 | Dell A940 All-In-One InkJet Printer
Clean Unable 46 how pleaes brother dcp130c
The message "Unable to Clean. " will appear on the display if there is a
mechanical malfunction of the Brother machine OR a foreign object, such as a paperclip or ripped piece of paper is stuck in the
machine.
First, check the machine for any foreign objects:
1. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place. Look inside the Brother machine and remove any foreign objects.
2. Close the scanner cover by lifting it slightly to release the lock,
gently push the scanner cover support located in the back of the unit
and then close the scanner cover.
3. If the error message continues to appear on the display the machine
will need to be reset. To reset the unit unplug the Brother machine
from the power outlet for several minutes and then plug it back in.
If the message continues to appear on the display and your machine is
within warranty, you can locate a Brother Authorized Service Center
(ASC) in your area by clicking on the link below:
http://www.brother-usa.com/service/default.aspx or contact Brother
Customer Service by calling 1-877-Brother (1-877-276-8437) Monday
through Friday, excluding holidays.
If your machine is out of warranty, you can locate a Brother Authorized
Service Center using the information listed above.
Please Let me know if this works, or if it does not.
Thanks,
Ryan Frame
Creative Energy Associates Technical Center
Aug 02, 2009 | Brother Office Equipment & Supplies
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error 50c Using real Dell carts Tried reinstalling drivers still
Hi there Error 50c
Here we go try this out.
color cartridge.
Mar 26, 2009 | Dell A940 All-In-One InkJet Printer
Error Code problem
My mother's printer had a similar problem, I was able to find this solution on the HP site.
Disconnect the USB cable from the back of the printer, but leave the printer turned on.
Open the cover of the printer and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the printer and wait for one minute.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
I hope this helps you too...
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother DCP-110C All-In-One InkJet Printer Logo
611 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
