Question about Pitney Bowes 9920 Plain Paper Fax
I have a paper jam on my Pitney Bowes 1630. The
I have a paper jam on my Pitney Bowes 1630. The paper is stuck in the fax by the rollers. Need to know how to get the paper out?
Posted by dbromley on
Nike Merritt
  • 149 Answers
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Posted on Feb 24, 2010
I have a Pitney Bowes Model 1630 copier / printer, Message "Printer Jam offline" .No Paper jamed in unit...How can I fix ?
A sensor is probably blocked or a torn piece that cannot be seen is in there. Take a can of air to it. Also turn it off and turn it back on for added measure.
Mar 09, 2011 | Pitney Bowes Office Equipment & Supplies
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Paper jam on Pitney Bowes 9910
try a new toner, if not it could be fuser
Feb 17, 2009 | Pitney Bowes 9920 Plain Paper Fax
Our Pitney Bowes 1810 Folding Machine hums & the document dial for the folding style does not move! Help!
Problem is not fixed. It does not involve a fax machine, it involves a Pitney Bowes 1810 document folding machine. Not interested in paying for "service" - it appears as though your service would be of any help.
Thank you
Jan 26, 2009 | Office Equipment & Supplies
How to connect pitney bowes 1630 to PC
you will a usb cable and driver software.should not have any other problems
May 06, 2008 | Office Equipment & Supplies
Sharp F0-1460
"DOCUMENT JAM" refers to your original document that you are trying to send. Lift the top of the Automatic Document Feeder (ADF) and look for a tiny peice of torn paper. If not, look for a stuck sensor flag (might look like a small plastic finger). If still no go, clean the roller that feeds the original, it may be worn out and slick. Hope it helps Ed
Jul 13, 2007 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes 9920 Plain Paper Fax Logo
225 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
