Question about Maytag Atlantis MAV6451 Top Load Washer
Defective lid switch I think
When I open the lid my washer stops.  I have had to hit near the lid switch and it would run fine.  Now this doesn't work.  what can I do until I get a replacement switch?  How can I get it to work.
Posted by susan57 on
Mike Johnson
  • 291 Answers
Sounds like your lid switch is ok .. u need to replace or adjust the plunger for the switch... below is a pic of the plunger.. sometimes u can get a little adjustment on the clip that pushs the plunger thats attached to the lid.. pic below
sounds like this is the part that has wore and shorten some...
also check the lid cam maybe able to wedge something behind to get more length out of the plunger heres a pic
Posted on Oct 27, 2007
  • Mike Johnson
    Mike Johnson Oct 27, 2007
    To be sure switch is still working you can see where the above cam will push on the plunger.. push with something and listen for the click and see if wash will work... if so replace plunger and maybe cam .. you maybe able to figure out how to get more length untill u can replace
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Sep 22, 2012 | LG WM-2032H Front Load Washer
I have a key came on my washing machine will not which on
see the causes, and fix it.
1) use the key and see if the key is o.k , test the recipint may be is defective, this is a electrical switch.
2)If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. 9_23_2012_4_33_11_am.jpgsee your wiring diagram behind the machine. or you must open the covert from the control and your will see it.
Sep 22, 2012 | Bosch Washing Machines
Dryer doesn't stop when door is opened and light does not work (new bulb)
see the next steps and proceed with common sense: God bless you
Aug 01, 2012 | LG Tromm Electric Dryer
Admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
I have a washer kemore 600 series, it pumps water in but will not do anything else. Is there a reset button on the motor or pump?
Hello there and welcome to fixya
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? try to unplug for 15 min then reset the home breakeer than plug in the machine again and try Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video . at repair clinic.com Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or it will fill but will stop after that
Sep 12, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Washer won't agitate or spin
there are several things that you will need to check first ok please verrify the following
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
The washing machine has stopped working and no lights come on
Hello there
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 07, 2010 | Hotpoint Washing Machines
Washer won't turn on, do I need a new door switch?
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 27, 2010 | Washing Machines
WASHER QUIT WORKING BEFORE RINSE CYCLE AN WILL NOT WORK ON ANY OTHER CYCLES AND IT DOES HAVE POWER GOING TO IT
Jan 03, 2010 | Washing Machines
Kenmore washer machine cylce stopped in mid cycle
  • No power
  • Lid switch
No power
Lid switch
 check these, if still the problem persists then let me know for further help.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
155 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
