Question about Maytag Atlantis MDE7400AY Electric Dryer
No heat during cycles
Dryer seems to function properly but has no HEAT during cycles. ???
Posted by rogersig on
Robert Hirst
  • 833 Answers
First, check your breakers and wiring. There are two breakers usually linked together. Turn both off and back on. Not that? Make sure you've got controls set right. Still? You will have to shut power, get a multimeter and use the diagram on the back of the unit to see if the thermostat is working, the high limit is continuous and the elements are good.
Posted on Dec 21, 2007
I have a Samsung DV330AEB XAA 04 dryer. It has been turning off during loads on high heat timed dry. Any ideas as to why?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Nov 19, 2014 | Samsung Dryers
Dryer does not heat at times and does at other times
There may be a loose connection in your wiring. Start at the receptacle and work your way into the dryer. Assuming this is an electric dryer, check to see if the elements are ok. But , I. Really think it is in the control switch. Do you get any heat AT&T all when it does not function properly. This will help me going forward.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
No heat during drying cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]]\][
Jul 21, 2011 | Dryers
I have a Kenmore dryer model #96565210 65652 that is not heating up. All functions of the dryer seem operable, but at the end of a drying cycle, the clothes are still wet. Seems like the heating element...
heatman101
Jul 16, 2011 | Kenmore Dryers
Tumble dryer does not heat up during cycle
heatman101
Jun 07, 2011 | Miele Novotronic T230C Electric Dryer
Dryer does not heat clothes during drying cycle
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 26, 2010 | GE DBL333EA Electric Dryer
My dryer has not heat during cycles... How could I check for heating problems?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Maytag Neptune MDG9700A Gas Dryer
My Maytag Alliance gas dryer won't heat up at all. The dryer keeps running due to the temperature not changing. There is no heat at all. I ran out of propane - the dryer stopped during the cycle, the...
heatman101
Sep 05, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Gas Dryer has heat at beginning of cycle then no heat.
heatman101
Jun 05, 2010 | Whirlpool LGR3624JQ Gas Dryer
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Maytag Atlantis MDE7400AY Electric Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
