Question about Compaq Presario 700 470024-192 Notebook
Compaq c700 wi fi not working i tried pressing the wifi button but still the LED stil red.
Posted by denniscas10 on
Anonymous
  • 108 Answers
Have you checked that the wireless network connection is not disabled in "control panel" "network connections". Also check Device Manager and make sure that the wireless device is listed under network adapters. Have you turned off the wireless device in the bios? If you need help with any of these let me know. I will also need to know which operating system you are using i.e. XP or Vista
Posted on Jun 09, 2009
How do I use wifi on my Alcatel 392cc phone
Teresa, Instructions on connecting to WiFi, press options button, settings, wireless network, WiFi,WiFi settings, choose the network. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to connect to Wi Fi on my ALCATEL ONETOUCH Idol
How to set up Wi Fi on an Alcatel One Touch
Connect to Wi Fi
Aug 11, 2016 | Alcatel Cell Phones
Lap top wireless connection to internet router
you need to turn on the wifi button on router
Feb 16, 2014 | HP Compaq nx6110 PC Laptop
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Jul 29, 2010 | Lexmark Z2420 Printer
I LOSS MY WIFI DRIVERS OF PRESARIO 700 TELL WEBSITE FOR DOWNLOAD
depending on the version of the C700 series you will have to select it from this list
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&query=PRESARIO%20c700%20&dest_page=softwareCategory&tool=softwareCategory#N430
after you do, you will be provided links to all the drivers available
Feb 21, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq Evo N610c Wireless Problem!
FN+F2 is given to disable and enable the wi-fi means once you will press it the wifi will turn on and in second attempt it will turn off.
Check in device manager whether it is showing any wireless ethernet controllerand if not then install.
Thanks.
Dec 09, 2009 | HP Compaq Evo Notebook N610c
Where is wifi switch on the compaq laptop?
Well, you haven't given the model number to your compaq. I will try to assist you the best I can, if this doesn't help then I ask that you provide the model number. Some of the Compaqs have a button right between the keyboard and the monitor(it looks like this: http://www.hp-pavilion.ru/Catalogimages/Compaq-Presario-C700/29945.jpg). Others will have a switch somewhere with a orange dot/light near it. If you don't see either of these then there is probably a function key for it. Incase you don't know how function keys work, functions are usually located under the F1-12 keys, you hold down the FN key and press the corosponsding Function. The Wi-Fi function key usually has the same symbol as the one in the picture above. If all else fails and your WiFi still isn't working you could have a more indepth issue.
Nov 20, 2009 | Compaq Computers & Internet
WI-FI
if you have the same problems with usb then your problem lies outside the laptop. if your led does not light it is possible your laptop wasnt wired for wifi or your led is not working. Where you place the wifi card is there 2 wires 1 black and 1 white
Aug 29, 2008 | Toshiba Satellite A10 Notebook
Can't download compaq 754 tu laptop wi fi drivers
Hi
Try this link:-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3674870&lc=en&cc=us&dlc=en&submit.y=10&submit.x=2&lang=en&cc=us
May 19, 2008 | Computers & Internet
HOW TO START WIFI SERVICES IN COMPAQ PRESARIO C700
hi , r u using win xp or vista, if u r using win xp , then its one of the compatiblity issue of this notebook with win xp. wifi will work but the led will always be red.
sunder singh
May 18, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
366 people viewed this question
Top Compaq Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
