Sunbounce Pro Textile, 4x6 Black / Softwhite Screen Logo
P
Pat byrne Posted on Feb 15, 2014
Nokia lumia 800 screen goes blank in middle of call. When I squeeze top of screen it appears momentarily. Have to press start button to get home screen to re appear
Kate Henkel
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 04, 2014
Kate Henkel
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
1106
Points
15
Check your screen time-out settings. Mine was doing that because it was set for 30 seconds.
Nokia Lumina 1020 locked on Optus Australia
Hello. Do you want to unlock your Nokia Lumia 1020 from Optus network restriction? If so, You can unlock it safer and easier using unlock code. You can get the unique unlock code for a Nokia Lumia 1020 from Unlock-Zone.com at affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch on your Nokia Lumia 1020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 1020.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 1020 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 1020
Nov 20, 2014 • Cell Phones
2answers
Nokia lumia 520 unlock pin required
Hello. To which network has your Nokia Lumia 520 been locked to.? You can get the unique unlock code for a Nokia Lumia 520 from Unlock-Zone.com at affordable cost. Good luck.
1 - Switch on your Nokia Lumia 520 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 520.
4 - The Nokia Lumia 520 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 520 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The CODE you need to enter is the unique unlock code for your Nokia Lumia 520
SOURCE: MobileUnlockGuide.com
Nov 11, 2014 • Cell Phones
1helpful
Nokia lumia 710 should be unlocked
Hello. What kind of unlock are you asking for your Nokia Lumia 710? If it is a network lock, you can visit TheUnlockSpot.com and get the accurate unlock code at affordable cost to get it unlocked. Good luck.
1 - Switch on your Nokia Lumia 710 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 710.
4 - The Nokia Lumia 710 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 710 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia Lumia 710
How to get unlock code for nokia lumia 520,imei :351737060551944
Hi. You can get the accurate unlock code for your network locked Nokia Lumia 520 either from the respective network provider or from trusted online vendors like MobileUnlockSolutions.com at affordable cost.
4helpful
How to unlock a phone. Nokia lumia 520
Hi. You can unlock a Nokia Lumia 520 safer and easier using unlock code. You can get the accurate unlock code for your Nokia Lumia 520 either from your respective network provider or from any trusted vendor online like TheUnlockArena.com at affordable cost.
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
2helpful
3answers
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Sunbounce Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Sunbounce Expert? Answer questions, earn points and help others
