Question about HP Pavilion N5415 Notebook
Removing hardrive from HP laptop
Can you tell me how to remove the hard drive from my HP laptop and where the hard drive is? I want to get rid of my laptop but I am selling it cheap and do not want any of my info on there.
Posted by tdstinson on
  • tdstinson Oct 27, 2007
    Can you also tell me if there is way I can make sure my hard drive is cleared and clean off so that no one can view my personal info with out taking out the hard drive and without going to best buy to pay them 60.00 to do it. I am getting rid of this laptop for a small amount.
Jay Green
  • 24 Answers
This is well past when the original question was asked, but there may be others who need the help.
The HDD is located EXACTLY under the keyboard. Unfortunately I don't have pics or a video, but I can take you through a quick step by step process.
1: Close the laptop and view it from the rear where all of the ports are. There are 2 hinges for the screen. Remove the 2screws that or in those hinges. They are only holding a plastic cover in place.
2: With the screws removed, open the laptop and open completely, so the laptop is laying flat open. At the top of the keyboard is the button panel and removes fairly easily. Use a small and thin flat tip screwdriver to carefully lift up this panel. I started from the right side as it is easier to pop off. The left side is a little more stiff. Once you get most of the right side up, gently pull to the right and wiggle carefully top pull the panel completely off.
3: The set screws for the keyboard are now exposed. There are 4 of them. Remove them and you should easily be able to lift the top of the keyboard and fold it gently towards the front. Do not pull or disconnect the keyboard.
4: The Hard Drive should be completely visible now. There are 4 screws holding the caddy down. Loosen these screws completely. They should not come out. After the screws are loose, pull on the strap at the front of the caddy. Pull straight up firmly and carefully. You may want to jiggle it slightly to work it up, and be prepared for it to pop out on you. It can be in there pretty stiff, and you don't want to damage any thing.
5: If you need to, remove the drive from the caddy, take the connector on the drive pins off first, and then remove the 4 screws attaching the caddy to the HDD.
Closing it up should follow smoothly in reverse order.
Hope this helps.
Posted on Apr 17, 2009
Anonymous
  • 47 Answers
There are a set of screws on the bottom.  You unscew them (4 I think) and if should come right out
Posted on Oct 27, 2007
  • Anonymous Oct 27, 2007
    you can do this a couple of ways.  you can run a FDISK on it to wipe evereything.  this takes are of the partition.  You should then run a low level format.  This is a good way to wipe it out.  Google low level format and there are some free softwares out there for it.
    Thanks
How to wipe a hard drive
Easiest was is to reformat the drive or reinstall your windows OS as a new install. Either way, will reformat the C: drive and wipe all data from the drive. You may have a security program that allows you to shred data. That, too, will work as it actually removes data rather than just removing the indexing files pointing to the date, such as emptying your waste basket does.
Aug 15, 2014 | HP Computers & Internet
Disk full on "e" drive HP tools
Time for an external hard drive. Prices are excellent for large capacity hard drives too. Down load CCleaner. It's a free program that gets rid of useless files left behind when web surfing. You can pick uo a huge amount of disk space using this program.
Jan 19, 2014 | HP "Compaq Presario Cq57 Laptop Amd Dc E...
Were can I buy a cheap or used 40 gig or smaller hard drive to test a HP NC6000
Hi Pat ,
go online to www.drivesolutions.com and see if they have one , if not try www.newegg.com and let me know if they dont , will advise futher......Goodluck Roy
Nov 21, 2011 | HP Compaq nc6000 Notebook
How to format compaq laptop nx6110
Hi
you could try to do this
Please try to save any files or pictures that you need before you do this either to a usb spare hard drive or a usb pen drive because you will loose it all if you format or reinstall windows
press the power on key as well as the F11 key
hopefully this will take you into the factory restore
which will format the hard drive while it restores
if you just want to format the hard drive itself then you could remove the hard drive
connect it to another computer via a usb cable and use the other computer to format the hard drive that you removed
or there are some good software out there that you can bootup with and format your drive without removing it from your laptop
a bootable spotmau would do the trick but its not cheap to buy
norton system works is another good software
pleasse let us know if this has helped you
many thanks
Jul 08, 2011 | HP Compaq nx6110 PC Laptop
I think my zune is fried. every time i turn it on it makes a clicking noise and on the screen its says 5 & contact support. tell me wht you think it is.
Most zune 120s and 80 gigs with code 5 or 3 need major repair due to hard drive failed I see alot of them for sale.hard drives are not very cheap. seems to me that ms bought cheap drives.so send it in for repair or sell it.
Sep 13, 2010 | Microsoft Zune JS8-00001 Digital Media...
Replacing the hard drive in my HP Pavilion N5475
Try HP website they usually have good info on replacing parts by model #,,,,,,,,,,,
http://hp.com/support
Jul 06, 2010 | HP Pavilion N5475 (F3927H) PC Notebook
Space bar missing on hp dv9000 laptop
hi go to this site and absolutely u will be able to change ur keyboard with new one http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
Jun 06, 2009 | HP Pavilion dv9000z Notebook
Help- CD Rom works sometimes
all you need to do is just have CD-ROM replace , they're cheap and easy to get , ebay selling it , not too hard to install it either .
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Disk clen up
first start by getting rid of all the mp3's that might be on your hard drive. Download www.ccleaner.com and run it- it will get rid of most of the temp files on your hard drive. Go into add remove programs and delete unneeded programs. Online support can help you do this too. Try www.plumchoice.com they can fix it over the internet!
What you probably need is a much bigger hard drive- they're cheap, but you might need help installing it, and setting it up. A local computer guru can do this easily.
Oct 29, 2007 | Compaq Presario Notebook
HP Pavilion N5415 Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
