Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I have nikon d40, on continuous mode, auto, it doesn't shoot continuously. also, most of the time, it focuses but not shooting... please help.
Posted by jv_gandz on
Z Laws
  • 375 Answers
I don't know what you are doing - mine shoots continuously with no problems. There is nothing to set other than to set the shooting mode.
I have noticed that some memory cards are so slow it doesn't allow continuous mode. I recently replaced mince ith 16G class 6 cards and they work fine.
Posted on Jun 30, 2009
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
Can not get continuous shooting to work on my nikon d40
Sometimes a slow card cannot keep up with continuous shooting.
Oct 28, 2010 | Nikon D40 Digital Camera
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Flash witeout
Hi there, you mentioned continuous shooting right. Your mean Sequence mode? One click and 7- 12 continue image sequence wise? If its then the problem is, your camera battery is not good now. He is not able to give required power supply to you camera flash. When few snaps done after the he loss his battery power & flash power going under(-) & your camera motor going slow, that's why shutter not open and close proper time. And the final result is whiter & whiter images. Hope you understand, what i am saying. So change the battery & buy a new original battery.
Thanks & waiting for your feedback.
Feb 15, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
D40 does not shoot on auto mode
on the side of the lens check to be sure it is set to auto and not manual.
Oct 15, 2009 | Nikon D40x Digital Camera
How do I get my nikon d40 to take Black white pictures?
You CAN!!! shoot in b/w with a d40, the only thing is you can't shoot in auto mode it has to be manual , aperture priority, or shutter prioirity. Go into menu - shooting mode - optimize image. you'll find it in there.
Dec 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Can't enable manual white balance and other options on nikon d40?
white balance can only be manually configured on "PSM" modes only, the other modes set the white balance automatically .
Sep 25, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
Dec 09, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
288 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
