Question about Toshiba 36A40 36" TV
Green vertical line
I have a flat screen toshiba with vertical green line, and looks like it appears only when the tv is warm.
any help????
Thanks
Posted by mvanswol on
Anonymous
    Novelist:
    Champion:
  • 275 Answers
This is generally the case when the Horizontal Yoke Coil is defective.A defective Hor. Deflection Coil bad is very very rare. 9 cases out of 10 it is a dry / bad solder.If you are versed in Solid State Electronics, I advise you to Unplug the TV and carefully open the back panel. There will be a Coil mounted on the neck of the Picture tube. It will have 4 connections and there will be 4 wires leading from it to the Main PCB. Check these connections - both on the Coil and on the Main PCB. If these are OK, then call in a qualified Technician.Nothing more you can do.
Posted on Jun 09, 2009
2answers
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
I have a L.G. Model #DU-42py10x 56in tv that has red and green vertical lines on tv when started up. does it need a new chip?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
2answers
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
1helpful
Thin black verticle lines on screen some disappear when warm toshiba wide screen tv
The post is a bit confusing. However, I have a Toshiba 42rv530u model where vertical lines appeared. Tech came out and ordered a new panel. It sounds like the same situation with you.
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
24helpful
4answers
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
2answers
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Toshiba 36A40 36" TV Logo
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
