Question about Fishman Music
I am trying to wire in the guitar jack on a Martin DC 16GTE. It has a white wire a red wire and a black wire. There is a selection for A Blend and B Blend. I have the red wire connected and it produces sound on Blend B but I have attached the White wire to the only two other post available and I can't get anything on Blend A. What is the concept here and how should I wire it? Any feed back would be very much appreciated. I am doing this as a favor for a friend. Thank you. Dave R
Posted by draynor on
Teraya
    Problem Solver:
  • 5 Answers
I know this is more of a referral than a solution, but I'd go right to the source and contact Martin's customer service folks. They should be able to either get you a proper "wiring diagram", or possibly just describe the jack wiring to you. They have a phone number and an email address posted at this link...
http://www.martinguitar.com/services/customer.html
Now if I had to guess, I'd say both the A & B blend wires probably both go to the "tip" connector of the jack (otherwise, it would require a weird non-standard setup to function properly, like using a stereo guitar cable or something, very unlikely).
Posted on Jun 09, 2009
How do I change the battery in a martin drs2 guitar
if you look inside the cavity you will see a black nylon insert that is velcrod to the base. simply pull it off its velcro , swap the battery out , and then revelcro it. Super simple.
Nov 09, 2013 | CF Martin 000X1AE Java Mahogany Acoustic...
How do I open the battery compartment on the oooCXE
The little latch is above the word "Fishman" right in the center top of the tuner. With a fingernail, pull the latch toward the center of the tuner and the whole thing pivots out exposing the batteries.
Jul 20, 2011 | Martin Guitars Martin X Series: 000CXE...
My deville has just stopped producing any sound what soever. All the tubes glow and the red power light is on but no sound. I have tapped the sides of all the tubes and they all register a sound except the...
The first thing i would do is not leave it on in this way for too long. You could blow out a very expensive Transformer if its a faulty speaker. The worst thing you could do to a TUBE amp is run it without a speaker . I would test the speaker first. Just remove the wires going to it. And connect the speaker to either a car stereo or house system at low volume very low. And see what you get. if it works ? Good! Now check your guitar chord/wire. Try different ones try different guitars. If that doesn't work . Look into the input jack on the instrument input hack on the amp.. They do come loose off the board.Either get a new input jack or resolder the old one. if you only have one guitar look at the guitar output jack. Loose wiring on the guitar could cause this also. Dirty In and out put jacks could cause this. A pencil with Very fine sand paper wrapped around it will clean a dirty input/output jack. Try these things. Just remember poking around your amp is Dangerous. The electrical components hold a charge even unplugged that can kill you. No joke..
Dec 26, 2010 | Fender Hot Rod Deluxe Guitar Combo...
CAN I FIT A FENDER STRAT PICKUP IN THE MUD
The Fender pick up has two wires, blue and white. The Jackson has four: red, green ,black, and white.
1st. Determine the hot wire and the ground wire on the Jackson pick up and then just replace the Jackson pup with the Fender pup. White on the Fender is the hot lead and blue is for the ground. If you hook it up backwards it will be out of phase with the other pup's and will sound thin and weak when selected with either the rhythm pup or the lead pup. Of course, by itself it will sound normal because switching the wires only changes the phase of the Fender pup.
On the Jackson pup, the green and black are ground while the white and red are the hot side. Just solder the white lead of the Fender pup to the pup selector hot side and the blue lead to the ground.
Aug 01, 2010 | Jackson Dk2 Dinky Electric Guitar Eerie...
I need to repair internal wires
Typically you have to unstring the guitar to get access to the insides.
Use a small miirror to view the insides. You may need to drag the jack out of the sound hole to resolder wires if they are broken. There should be three wires on the jack. One carries the audio, one the ground, and the third connects the battery when the instrument cable is plugged in.
After re-soldering the connections if needed, procure a piece of 1/4 inch wood dowel from your hardware store. Push the dowel through the hole where the jack goes and near the sound hole. Push the jack onto the dowel and then pull it back through the jack hole and pass the nut over the dowel and onto the jack threads and tighten. The extract the dowel rod from the jack.
It is near impossible to reach clear into the guitar body to put the jack back in without the dowel rod unless you have very tiny arms.
Feb 09, 2010 | CF Martin Music
Changing the output Jack on 1985 Peavey Dyna Bass
If this has active circuitry, one of the wires is the cutoff for the power supply from the battery. The other two are black for ground and either white or red for signal.
Mar 13, 2009 | Peavey Music
The pick up on my son's Martin LXME won't work
Take it to a guitar shop and have them check out the soldering and connections within the guitar.
Martin has a record of cutting corners on their less expensive models.
Jan 13, 2009 | Martin LXM "Little Martin" Acoustic Guitar
Music Logo
299 people viewed this question
Top Fishman Music Experts
rhodesworks
Tom Chichester
Are you a Fishman Music Expert? Answer questions, earn points and help others
