Question about Freecom Classic CD-RW Burner
Hello pls help. My IBM x20 laptop always display "error 0198 power source is battery" during booting with no adapter plugged in. anyone pls help...
  • Steve Brown
    Steve Brown May 11, 2010
    Just wondering if you had thought about replacing the battery.
    the battery may be bad. I looked and looked and nothing really comes up in the search engines.
    and appearently it's an IBM thing.
    what operating system in on the laptop?
    Sergeant:
  • 233 Answers
I assume that you are trying to boot off of your battery and that possibly an update to your BIOS was performed and now you need to boot with a power adapter plugged in. IBM is touchy with this kind of thing. If you have your adapter plugged in, I might check to see if it has a light to indicate power on it and if it doesn't check the adapter where the power cord from the wall plugs into the adapter to make sure it is well seated.
Posted on Jun 09, 2009
I am currently working on a Thinkpad with the same problem. I found that if i press the Esc button when the message is displayed it will boot. I am still searching for a real fix.
Posted on Sep 19, 2009
6ya staff
SOURCE:
I have a samsung R620 laptop but the laptop is not booting but the battery and ac adapter are working properly on the system because the battery light shows or indicate tha the battery adapter is okay but...
By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Sep 13, 2017 | Samsung R620-64BR Laptop Computer
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
White screen display
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for LCD issue.
Mar 16, 2011 | Computers & Internet
A white screen display on my laptop
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center or contact ASUS (if in warranty) to have it check for LCD problem.
Mar 16, 2011 | ASUS LCD Monitor
Screen lights up for a second during boot cycle then goes black laptop is a toshiba tecra when you hook it up to external monitor you can see display
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Feb 23, 2011 | Toshiba Computers & Internet
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
Freecom Classic CD-RW Burner Logo
206 people viewed this question
Top Freecom Computers & Internet Experts
Geoff
Jeffrey Groves
Jeffrey Groves
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
