Model wtw6600sw1 whirlpool cabrio washer won't balance even empty
The round rubber like disks on the bottom of the suspension rods have some interference between them and the rod. This interference causes drag. So when the spring tries to push back the disk slows the recoil down giving it a damping affect.
Hope this helps.
SOURCE: 5 month old Whirlpool Cabrio washer has moldy
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
SOURCE: WTW6600SW1 whirlpool cabrio washer keeps
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
