Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Refrigerator stopped dispensing water
My Kenmore Ref's water dispensing system stopped dispensing water. The ice maker still works. Wmorehat seeme to cause the problem? Thanks.
Posted by nonoy_62 on
  • 9 more comments
  • dkonda Nov 12, 2007
    The water dispenser stopped working. The instrument panel lights are not on. I do not understand what is the problem. Any advice will be greatly appreciated.
  • vickybrown Jan 05, 2008
    my fridge just started doing the same thing yes. no water comes out but ice maker still works. ive tried holding the switch for a min or so to see if any bubbles etc...nothing. it doesnt even make any noise.???? help
  • northern gal Jan 06, 2008
    Our 2 week old side by side dispences ice no promblem but stopped dispencing water. It seems to have power but no water. I suspect the water line is frozen as suggested,but Where is it? There is nothing in the manual of the location and in waiting for the repairmen to call next week to make an appointment to look at it I would love to solve it myself. The manual in troubleshooting doesn,t give any of the possible solutions that the letters in this forumhave given which seem the most logical and easy solutions. The manual gives complicated promblems and solutions. Not impressed. Hope someone here can help with the location. Thanks
  • Anonymous Jan 17, 2008
    i have a kenmore refridgerator model number 25357672791 it has stop dispensing water and there is no humming , but the ice marker is still working... please help this stopped working about 8 months ago
  • bateman Jun 02, 2008
    model #57572791 does not dispense water
  • Anonymous Mar 13, 2014
    Water dispenser chatters when drawing water
  • Anonymous Mar 23, 2014
    Kenmore refridgerator model # 10655649500
  • Anonymous Mar 24, 2014
    Water dispensed from refrigerator is full of floating debris.
  • Anonymous Mar 30, 2014
    Serial k13904691. How can we fix this problem, thinking the valve went bad
    Water does not come out of dispecer when you dapress ******, but water is getting to ice maker
    water won't stop dispensing
Anonymous
  • 100 Answers
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
  • 1 more comment
  • wookie_bach Dec 10, 2010
    Try cleaning out the grate at the bottom of the fridge. If it hasn't been cleaned in a while there can be a grime build up almost like the lint build up in a dryer. Once that and other lruking debris is removed water should resume dispensing. Hth!
  • Terry Krok
    Terry Krok Sep 16, 2012
    Thank you for your response. Yes I do hear the noise when the glass is pushed against the switch. cubes and crushed work, just the water doesn't come out.
  • John
    John Mar 08, 2014
    On the Kenmore refrigerator model 106 keephe recommended setting of 38 degrees any lower could cause the water tank to freeze and your water dispenser will not work. NO WATER...
bateman
Door does not dispense water ,but it does make ice...whats the problem..model #57572791
Posted on Jun 02, 2008
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
253.57189601 parts list
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 22, 2012 | Kenmore Refrigerators
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
WATER DISPENSER HAS STOPPED WORKING, HAD BEEN WORKING FINE THEN JUST STOPPED. WASNT SURE IF FILTER JUST NEEDED TO BE REPLACED OR IF MAYBE THE WATER LINE WAS CLOGGED. THE ICE MAKER IS WORKING FINE,
check your water tank in ref. it is behind veg. drawers.. if water tank is full. might check water soldnoid in b back of ref. there should be two one for ice maker and one for water..ok
Feb 13, 2011 | GE GSH25JFR Side by Side Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
2,622 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
