Canon Master
- Posted on Jun 11, 2009
Re: Pixma mp480 jams paper!!! It occurs on the left side...
Please try this and also try cleaning the printer and the paper rollers that it has.
- Turn off the printer.
- Remove any paper trays. Inspect them for wrinkled or damaged paper.
- Also open the back cover of the printer if this model has one.
- Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
- If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
- If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
- If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
- Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
- If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
- see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Thank you so much for the feedback Indeed, the problem was a debris, a BIG debris problem... It was a bolt/screw jijiji I have no idea how it got there but fortunately its gone and solved my problem. I wouldn't have noticed if it weren't for your message, I bought a dust remover spray and the straw looking thing came off and went somewhere into the tray, I had no idea where it went so I had to turn the printer upside down, and WALA thats were I heard the clinging noise of the screw. hopefully it does not belong to the printer and it continues to work fine... Again thank you!!!!!!
