Zenith IQB32B42W 32" TV Logo
Question about Zenith IQB32B42W 32" TV
Zenith 32" TV Chirping Noise No Picture
I have a Zenith 32" TV and the picture wont show up and its making a chirping sound. any idea what's wrong? how to fix it? Model # IQ B32B42W
Posted by cb157011 on
  • cb157011 Jun 09, 2009
    Where would the 35v 100ufd capacitor and the flyback transformer be located in the TV?
  • Anonymous Mar 20, 2014
    2002 zenith model p60w26a Has sound but no picture Any ideas what's wrong
Anonymous
I have a 1999 zenith big screen,model #12902AN iF I UNPLUG IT WILL *** ON 3 SECOINDS THEN ALL THE GREEN LIGHTS ON BOARD WIL GO BACK OFF.
Posted on Sep 30, 2010
  • Anonymous Sep 30, 2010
    1QB60M92W 971-14201060 BOARDWILL POWER UP 3 SECONDS GREEN LIGHTS ON THEN EVERTYHING GO OUT----UNPLUGG WILL REPEAT BUT POWER BUTTON DONT CUT ON,...
Anonymous
  • 60 Answers
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Posted on Jun 09, 2009
RCA F32650 no picture
Sounds like the flyback. Mine did the same. I am in the process of trying to fix it. Try techlore.com for more help.
1helpful
2answers
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
1helpful
2answers
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
RCA F27667 No Picture / Chirping sound
I will bet you 10 to 1 that the flyback transformer and the horizontal output transistor is bad. an no at this point the set is not worth fixing.
Top Zenith Televison & Video Experts
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
