Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
Lost my charger too!
Anyone know where to find a replacement charger?
According to the owner's manual it is a :
14 VAC,1.5A UL/CSA-approved wall plug
adapter
Posted by farmers973 on
  • Mark Nov 30, 2011
    hello, were you able to locate a wall plug adapter? I am also in need of one :(
Jessica Harwell
  • 640 Answers
You can purchase a new charger for these swimming pool lights from the manufacturer or the retailer from which you purchased the product. They recommend that you do not use after market chargers not designed for this product. Their website is listed as www.cantar.com and the contact number listed on my warranty information is 800-448-2343
Posted on Jun 16, 2010
  • eddiejak Jun 07, 2011
    Good luck trying to find this cord!
Need to order fitbit flex 2 charger
Amazon, QVC, eBay and others offer the fitbit flex charge 2. However, you have expressed this as if you simply need a charger for the device. A UL tested wall charger would do that according to the Fitbit community.
Just how much support you would get from a particular vendor is a good question to think about.
Oct 21, 2017 | Exercise & Fitness
I need a power chord for a westinghouse 27" television
Hello
For the United States and Canada
In the United States and Canada the male plug is a NEMA5-15 style UL Listed, and CSA
Labeled. For LCD TVs that are placed on a desk or table, type SVT or SJT cord sets may be used. For LCD
TVs placed directly on the floor, only SJT type cord sets may be used. The cord set must be selected
according to the current rating for the LCD TV. Please consult the table below for the selection criteria for
power cords used in the United States and Canada
If the cord size is SJT take 14AWG _ 12Amps
If the cord size is SVT take 17AWG _ 12Amps.
The specific power cord for this LCD TV is enclosed and has been selected according to the country of
destination and must be used to prevent electric shock
Check the socket confuguration of your wall socket and select proper pluged cord.
OK.
Jul 02, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
No problem with unit. Is this air conditioner CSA or OSHA approved ?
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Mar 10, 2011 | Maytag M3X05F2D Air Conditioner
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
3 beeps every few minutes
That maybe a memory beep code. Turn it off and remove and re-insert the memory modules on the mainboard.
If this doesnt work, get back to me.
Feb 13, 2009 | Apex Computer Technology Apex Power Supply...
Compaq Ij300 Power Adapter
The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
Jul 15, 2008 | Compaq Inkjet Ij300 Printer
Compaq armada 1573d charger
According to the owners manual on the hp/compaq website, that notebook has an AC cord that plugs directly into the wall. Therefore the notebook must have an internal charger to convert the AC to a DC voltage to recharge the battery. Here is the link to see the manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00139858/c00139858.pdf
Just copy and paste the above link into your browser.
Dec 22, 2007 | Compaq Armada Cooling Fan Case Cooling Fan
What kind of capacitors are those?
Have another look at the capacitors you've got. If one of the leads is marked as negative (suppose it's possible that the other would be marked as positive instead, but the standard is usually to mark the negative) then you don't need a bipolar capacitor (for capacitors with one lead coming out each end, look for a band round one end of the capacitor with small minus signs printed on it. For capacitors with both leads coming out the same end, look for a stripe down one side). On the other hand, if there's no indication which lead is meant to be which, you probably need bipolar. If your application needs low ESR, then it needs it. If it doesn't, putting low ESR caps in will do no harm other than pushing the price up a bit and maybe having a bigger footprint. A.
May 04, 2007 | Insignia IS-LCDTV32 32 in. Television
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
1,322 people viewed this question
Top NRS Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
