Question about Sony KP-51HW40 51" Rear Projection Television
Screen fades to blue after 10 mins of viewing. Sony kp-57hw40
The problem started in Nov. All the sudden the picture was "concave". 6 months later, we can watch concave picture for 10 minutes, then the screen fades to blue. Sound is fine. The tv was manufactured in 2002. Help!
Posted by hinojosasand on
Julie Peterson
  • 18 Answers
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
P.S. you can also clean the mirrors and dry dust while you have it open.
Posted on Jul 27, 2009
1helpful
We have a Sony KP-57HW40 projection TV purchased around 2002. The screen fades to a blue and you can't make out the picture at all. What does this mean and can it be repaired?
This is one of a group of sets with bad picture tubes. If screen goes to mostly blue there is a way to attempt to get around it.
The tubes are expensive and only available on a rebuild basis.
I can tell you how to try in less than 10 minutes to adjust to compensate for the problem.
Do you want to know that to try/
I f this helps, rate this solution as very helpful as I do this here for free.
SD TECH
Have Sony Model# KP-57HW40 Big screen rear projection tv..Has blue wavy lines across screen, and sometimes flashes blue, can you give me assistance??
Blue Picture Tube , bad Video IC on Blue CRT board.Or Blue screen drive control to tube needs to be adjusted down some.
Most Likely Bad Tube!
1helpful
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Turn tv on screen is light blue then picture fades then, screen shuts off???
Blue tube is bad need to replace blue tube.. Tube no longer avail will need to be special ordered and my run from 350.00 up to replace part.
1helpful
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
2answers
Sony KP-51WS500
does it have blue video image?
2answers
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
