Worked fine one day and nothing comes on the next day? I've replaced the bulb a 7 years ago, but the light was the signal on the front. About a year later the color wheel was replaced. But now, nothing happens when you push the button. I got the TV in 2006. So is it fixable or just get another one?
SOURCE: Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
SOURCE: black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
SOURCE: samsung projection tv. tv went off, timer light is
Its probably shorted convergenc chips. You can get the parts and instructions from www.TvRepairKits.com
SOURCE: I have a samsung DLP TV, model HLN5065WX It is
Sounds like one of the plugs did not go back it properly on the DMD board or the ballast board. Check all connections.
