Televison & Video Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to remove close caption on screen panasonic model no CT-20G85G
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Jun 08, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
0
Helped
32864
Points
313
You need to go into your menu setting and turn ""cc" and any "text" to off position, gl, video-tek
Panasonic ct-34wx54. I cant remove the closed captions from the screen. When i go to the menu and try to shut it off the on and off modes are "grayed out" and cant be highlighted. Reset with...
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
Black square comes on tv
hi,
in your tv the closed caption option is in on position. make it off o run out the black square.
to make the closed caption (cc) off. do the following.
1. press the menu button
2. select setup
3 go to closed caption (cc)
4. select closed caption mute (cc mute)
ok
1helpful
Black box in middle of screen
enter in menu pressing the action bottom and turn off the close caption.
I have a Panasonic TV Model#CT-35625B, How do I remove the closed caption?
It is in video options if is not present then video contains subtitles, to clean it is possible through options.
http://www.cellphones2009.bravehost.com/
I have a Toshia TV - Model 19A24 - Made in Thailand - Dated Nov. 2004 # 7961C2877 A. With it, I have your manual control unit: CT-859. I accidentally pressed "menu" on the control unit. ...
Your closed caption is turned on. Go into the menu and set captions to off or look for captions button on remote. Sometimes identified as cc. Press it until "captions off "appears on screen. That should do it. Good luck.
Close Caption stopped working
might be eprom ic problems.
Black box in center of Tv
What you see is called a Text box and it is part of the CC or
closed-caption feature......go thru the menu pages until you
find how to activate / de-activate closed-caption and you will
get the text box off...........................................T.
Closed Captioning no longer works
check for the knub OSD on your remote to press it or at the menu select on screen display on
3answers
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
