Question about Dell Dimension 8400 PC Desktop
Dell 8400 , does not show having the CD or DVD players.
Computer is 4 years old and both drives worked the last time I used them, about a month ago. Last week the burner showed no recorder, and neither drive now will read a CD when placed computer.
Posted by Bob Gaertner on
Anonymous
  • 25 Answers
Either get a new Drive because it is spoilt or format the Com. Try the first option first.
Posted on Jun 09, 2009
My CD Player for a [Compaq] Presario V3000 hasn't been working. It worked fine less than a year ago, then it stopped working. My Computer doesn't show the CD icon any longer, not even Device Manager seems...
It will cost about $30 to buy a brand-new CD/DVD reader/writer.
Any computer-store technician can easily "manually" open your current drive, and remove the CD/DVD media.
Dec 14, 2010 | Compaq (120192-B21) CD-ROM Drive
Error with a TSST CD/DVDW TS-L532U.
Try uninstalling the device using device manager. Shutdown computer and restart. If the problem persists then you have a faulty DVD/CD drive.
Go to My Computer and right click, select the Device Manager, search for the drive on the right side. Right click and choose Uninstall. then restart. Hope this helps.
Jun 13, 2010 | Computers & Internet
Dvd cd drive not working
http://support.microsoft.com/kb/314060
Click the Fix it Link in this web page, and it will fix the issue. Quite painless
Jun 28, 2009 | Dell Inspiron E1505 Notebook
Dell Laptop inspiron B130 Cd/DVD player will not work
DVD43 is freeware and does not get updated very often. Although, there has been at least one update recently according to the threads I could find. I would try updating to the most current driver for DVD43 and see if that fixes the problem. If not try to remove the program again once the drivers have been updated. Some times a program will not remove through regular means when something in the program is corrupt. Hope this helps...
Jun 02, 2009 | Dell Inspiron B130 Notebook
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Error reinstalling Windows XP on Dell Dimension 8400
Sounds to me like the hard drive is bad.Download some testsoftware that does not require windows and test it.
http://www.seagate.com/www/en-us/support/downloads/
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
Dell XPS 200 CD/DVD reading problem?
the reade part of ur CD/DVD drive is damaged while the Burner is still ok .
1/use the cleaner disc.
2/replace the part.
3/replace the drive as a last solution.
plz do rate this post.
Dec 29, 2008 | Dell XPS 200 PC Desktop
I have a Dell desktop computer in my home office that is about 2-3 years old. It has a CD/DVD drive that is suddenly not working. The disc drive has disappeared from the options on "My Computer" and isn't...
Hi
Yes it is a common problem with Dell machines. Try right clicking on the icon in My Computer and selecting 'eject' If that does not work then just buy a new one and install. It is a straightforward job. just make sure the jumper connections on the new player are set the same as the old one
Dec 08, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Samsung Internal DVD drive and cd-rw drive not reconised
call dell they will help you get the necessary drivers
Nov 26, 2008 | Computers & Internet
CD/DVD won't eject, won't play, Device Manager doesn't recognize.
If it's only 8 months old, then you have atleast 4 months left on your warranty. The problem will either be the ide controller channel or the dvd drive and firmware has faulted, the same fault probably happens when you have put a dvd in and it wont read or eject. Return to the place of purchase, where the drive should be replaced or the notebook exchanged.
Aug 11, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
Dell Dimension 8400 PC Desktop Logo
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
