Question about Whirlpool Washing Machines
Washing machine will not drain or spin.
My wife had left the lid open on the washing machine on accident and since then the machine will not drain or spin. At one point, if you pressed down on the lid near the lid switch, it would start and work. Now we get nothing. As soon as you push on the lid it will start and then when pressure is released, it will shut back off like the lid is open. Is this the switch that has gone bad?
  • 3 Answers
HELLO: YES THE LID SWITCH IS BAD. TO REPLACE THE LID SWITCH YOU MUST REMOVE THE COVER ON THE MACHINE. FIRST REMOVE THE TWO PHILLIPS SCREWS FROM THE CONTROL CENTER ON TOP BACK OF MACHINE . TILT BACK THE TIMER AND CONTROL CENTER GENTLY. THERE ARE TWO FUNNY LOOKING LID RETAINER SPRINGS THAT HOLD THE ENTIRE THREE SIDES OF THE MACHINE TOGETHER REMOVE THESE WITH A FLAT BLADE SCREW DRIVER. REMOVE THE POWER PLUG FROM THE WASHER UNDER TOP. SLIDE COVER OFF MACHINE THEN REMOVE THE TWO PHILLLIPS SCREWS FROM THE LID SWITCH ASSY. UNPLUG SWITCH FROM COVER AND REPLACE WITH NEW UNIT . THERE IS ALSO ONE GROUND SCREW 5/16 THAT WILL COME OFF FROM UNDER NEATH THE COVER. THIS SOUNDS A LITTLE COMPLICATED BUT THE WHOLE PROCEDURE CAN BE DONE IN LESS THAN 10 MINUTES. THANKS FROM RUSTY AT [email protected]
Posted on Jun 09, 2009
6ya staff
SOURCE:
How do I fix a top loading washing machine that isn't spinning, agitating or draining?
if this is a top loader put a pencil into the lid switch opening if the machine spins and drains when the timer knob says it should the tab on the lid or the lid switch has failed...replace the switch or the tab that goes into the lid switch opening
Jan 26, 2016 | Amana Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Wont drain and spin
Pl click if helped.
Apr 17, 2013 | Whirlpool WTW4950XW Washer
My Whirlpool washing machine will not spin or agitate. The water drains out but does not always spin. If you turn the tank it tightens up and then spins properly.
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 10, 2013 | Washing Machines
Whirlpool Wfw9050x will not advance to spin cycle
Pl click if helped
Apr 08, 2013 | Washing Machines
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
My whirlpool front loader wont final spin
Pl click if helped
Apr 05, 2013 | Whirlpool Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Mar 30, 2013 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
124 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
