Looks like your computer is detecting a transmission/transaxle problem. Have you had your filter changed in the tansmission yet? Are you a little low on transmission fluid? Is the transmission fluid high like it's overfilled? Is your transmission fluid brownish and smell burnt? Just a couple of things you might need to look at. You may or even should take it to a reputible transmission shop and have them run a scan on it to see what the problem is. I know this doesn't seem like much help to you at this point and time but I would have it taken care of before any damage may happen.
Check the fuse box under the hood and under the dash, find the cooling fan relay or fuse. Sometimes there are relays mounted to the fan shroud itself. little black square plastic relay 1"x1" roughly. Look inside cover of fuse box for location or owners manuel. Check or replace the relay(s). Possible bad fan assembly though. Check for power.
places to check are under glove box , and or both fender walls of engine compartment, look inside any large relay cover boxes labeled fuses and relays...look for a 4 pin small box shaped unit about 1 inch square or so...
LOL LOL, sorry but that was funny(the light description). Not sure but if its the engine warning light you can go to Autozone or Pepboys. They will scan any engine code/s for free. Good luck.
