Question about NEC ND-2510A DVD±RW Dual Layer Burner
NEC DVD RW help
My nec dvd_rw nd-2510A I assume should work with a DVD-R. The dvd says 16x. I cAn't seem to make it record to it. I have firmware v2.15. Do I need to update firmware? If so, where is it and how do I do it?
Posted by jrpro190 on
  • 5 more comments
  • C Buehrle Nov 06, 2007
    DVD Not recording pictures?
  • Anonymous Dec 07, 2007
    Me too. Worked before,but made the mistake of upgrading to Vista. Now I have 24 Discs that I cant use. Surely someone must have the answer??
  • DSMD Dec 25, 2007
    I am also having the same problem. It records fine up to DVD-R with 8x speed. I tried Memorex and Sony DVD-R with 16X. It says the media is wrong. Any new updates/drivers Solutions?
  • oscarbay2002 Feb 24, 2008
    Same problem.. I ran out of 8x discs bought some new ones that were 16x and none of them will burn. I updated the firmware, updated the Nero software. Still no luck. Local stores don't seem to stock 8x media! Is this a plot to get us all to buy new burners.
  • rfrost707 Nov 10, 2008
    Same problem I believe, I was burning -R DVD fine last week then ran out of discs, purchases a new 50 stack of phillips and found I could not burn these so took them back. Came back with a new stack of Novatech (unbranded) DVDs and tried burning but still no luck. I can still burn some old +R DVDs I have and read DVDs OK so believe my hardware is operating as previously so, whjats the solutions? Is there updated drivers for the NEC2510 that can cope with the latest media or is it yet another ploy to get people to buy new hardware in the belief that theirs has gone faulty - yes the world has gone potty. How long is this kind of product support going to continue - are their no regulating bodies to ensure compatibility etc.
  • Kiawa Dec 08, 2008
    Same I had some older dics that where RW but ran out then got some new ones and now I can not burn anything.
  • die_walkure Mar 12, 2009
    I have the same problem. I only get this message "This unit cannot start (code 10)". It started with me not being able to burn some dvd's, now the unit don't even recognice any cd's or dvd's. It's simply dead. The device has a yellow triangle like an american yield sign with an exclamation mark inside on it when I check the properties of the unit. It says that the drivers is updated too.... I don't know what to do with it.
PROFESSIONAL COMPUTERS
  • 70 Answers
If you are using low quality discs for recording
the dvd drive cannot burn at its full speed
the writing speed depends upon the inserted disc quality and its supporting
Posted on Jan 21, 2008
Nec dvd rw nd 3500ag will not allow me to record on a 16x Memorex DVD-R disc.
There are DVD+R discs and DVD-R discs. It looks as though your burner will only write to the "+R" discs. I believe that is your problem. Try the +R discs which can be purchased individually or in 3 packs just to be sure. Good Luck.
Apr 23, 2011 | NEC ND3500 16X Double Layer DVD RW ND-3500...
My NEC DVD RW -3500AG will record using 8X DVD- R but not 16X can you advise
Dear friend please see your DVD top side, is there mention that DVD able to record 16X speed ? If not then you can't record that on 16X speed. Thanks.
Jan 29, 2010 | NEC ND3500 16X Double Layer DVD RW ND-3500...
Need to find the drivers ive looked everywhere
Here's the source
http://www.driversforwindows.com/nec_nd_2510a_firmware_3.26_22042.htm
Here's the driver
http://www.station-drivers.com/telechargement/nec/ND2510A_v326.exe
Dec 26, 2008 | NEC ND-2510A DVD±RW Dual Layer Burner
Cannot write to 16x dvd discs
Dunno. Do you have the latest firmware?
2f8 released August 24, 2008 is the latest version
=> http://www.findmysoft.com/drivers/Nec-ND-2510A-2f8-firmware-driver.html
Dec 11, 2008 | NEC ND-2510A DVD±RW Dual Layer Burner
Wont burn on DVD
Oct 23, 2008 | NEC ND-2510A DVD±RW Dual Layer Burner
Dual layer?
captmodley
NEC DVD + - RW ND-6650A is supprot dual layer dvd. for more information u can use this link: NEC DVD + - RW ND-6650A
Thank for asking
Jul 09, 2008 | NEC ND-6500A DVD±RW Dual Layer Burner
Works well on CDs, DVDs won't accept file into the file system in windows burning wizard
Jul 03, 2008 | NEC ND-2510A DVD±RW Dual Layer Burner
NEC DVD RW ND 2510A
check your disc speeds it won't accept anything over 8X, you can rectify go to cd freaks liggy and flash the firmware to 2.19 it worked for me
Apr 11, 2008 | NEC (nd-2510a) DVD±RW Burner
NEC ND-2510A DVD±RW Dual Layer Burner Logo
293 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
