Canon Laser Class 7000, when I hit delete memory it asks for the TX#, when I input the number, I am unsure what to do to delete. I tried the green button, the *, the #, the delete again, and I can't get it to delete.
Help.
Deleting a Document from Memory 1 Press [Menu]. 2 Use UP or DOWN arrow to select MEMORY REFERENCE, then press Start/Copy. 3 Use UP or DOWN arrow to select DELETE DOCUMENT, then press Start/Copy. 4 Use UP or DOWN arrow to select the transaction number TX/RX NO. of the document you want to delete, then press Start/Copy. The LCD displays YES=(*) NO=(#). If the LCD does not change after you press UP or DOWN arrow, this means only one transaction is stored in memory. If you are unsure of the transaction number TX/RX NO., print a list of documents in memory (see page 34). 5 Press [*] to delete the document. If you want to keep the document in memory, press [#]. 6 To continue deleting other documents in memory, repeat the procedure from step 4. To finish, press Stop.
Hope this helps. 1.) Press (system monitor) until <Fax Monitor> is displayed. 2.) Press - or + to select <2.TX/RX Transmission)->Press [set] 3.) Use the numeric buttons to select the transmission numbers of the fax job you want to delete-->Press [set] 4.) If you want to delete the fax job press [-] for <YES> Regards
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it. 1 Press [Menu]. 2 Use [up] or [down] to select , then press [Start/Copy]. 3 Use [up] or [down] to select , then press [Start/Copy]. ? Printing a Document in Memory 1 Press [Menu]. 2 Use [up] or [down] to select , then press [Start/Copy]. 3 Use [up] or [down] to select , then press [Start/Copy]. 4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and . If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34). 5 Press [*] to print the first page only, or press [#] to print all pages of the document. The fax prints the document.
Issue: How do I print a document stored in memory? Solution: Print the received fax from memory - MX310
Memory Reference
Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
Press , then press . [FAX SETTINGS] will appear at the top row.
Use to select [MEMORY REFERENCE].
Press .
Use to select [PRINT DOCUMENT] or [DELETE DOCUMENT].
If you select [PRINT DOCUMENT]:
Press .
Use to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST Press .
Use[ ] to select to print the first page only, or use [ ] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
Press .
To print another document, return to step 4b, or to finish printing, go to step 5.
If you select [DELETE DOCUMENT]:
Press .
Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
Press .
Use [ ] to select to delete document, or use [ ] to select not to delete the document.
Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
Here are the instructions from the onscreen manual from Canon USA.:
Printing or Deleting a Document in Memory
1 Press the FAX button, then press the Menu button.
2 Press the or button to select MEMORY REFERENCE.
3 Press the OK button.
4 Press the or button to select PRINT DOCUMENT or DELETE DOCUMENT.
If you select PRINT DOCUMENT:
(1) Press the OK button.
(2) Press the or button to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number by pressing the Numeric buttons.
If you are unsure of the transaction number, print the memory list. See Printing a List of Documents in Memory.
(3) Press the OK button.
(4) Press the button to select YES to print the first page only, or press the button to select NO to print all pages of the document.
(5) Press the OK button.
1)Open the One-Touch Speed Dialing panel, then press 'Memory Reference'.
2)Use up or down arrow to select 4.DELETE DOCUMENT. 3)Press 'Set'. 4)Use up or down arrow to select the TX/RX number you want to delete. [you can check the documents stored in memory by pressing < or > ] 5)Press 'Set'. 6)Press * to delete or # to cancel deleting. 7)Press 'Stop' to return to standby mode.
Reference page 8-8 in Canon LC2050P user guide.
1 Press [FAX], then press [Menu]. 2 Use [< ] or [> ] to select <MEMORY REFERENCE>. 3 Press [OK]. 4 Use [< ] or [> ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>. ▼ If you select <PRINT DOCUMENT>: 1. Press [OK].2. Use [<] or [>] to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the Numeric Keys.
If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".) 3. Press [OK].4. Press [<] to print the first page only, or press [>] to print all pages of the document.5. To print another document, return to branch-step 2, or to finish printing, go to step 6.▼ If you select <DELETE DOCUMENT>: 1. Press [OK].2. Use [<] or [>] to select <ALL PRINTED DOCS.> or <1 DOCUMENT>.
– <ALL PRINTED DOCS.>:
Deletes all the printed documents stored in memory.
– <1 DOCUMENT>:
Deletes a single document stored in memory. 3. Go to step 5.5 Press [OK]. ▼ If you selected <ALL PRINTED DOCS.> above: 1. Press [<].
Press [>] to cancel deleting, and the machine returns to the standby mode. ▼ If you selected <1 DOCUMENT> above: 1. Use [<] or [>] to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the Numeric Keys.
If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".) 2. Press [OK].3. Press [<].
Press [>] to cancel deleting, and the machine returns to the LCD of branch-step 1. 4. To delete another document, return to branch-step 1, or to finish deleting, go to step 6.6 Press [Stop/Reset].
First hit class a, b, c etc, and to clear out what is there, hit 1, then hit both memory and the one next to it at the same time to delete what is in there, To program, hit memory, then quickly, class a, b, c, etc. What it does it store that station in the NEXT AVAILABLE slot, so it is best to clear all slots, and have the station call numbers ready in the order you wish to set them.
Memory Reference
It may be necessary to press <Stop/Reset> to clear the error then
Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
Press <OK>.
Press <OK>.
Use to
of the transaction number, print the MEMORY LIST Press <OK>.
Use[ ] to select <YES> to print the first page only, or use [ ]
to select <NO> to print all pages of the document. (Received
Press <OK>.
Press <OK>.
Use
Press <OK>.
Use [ ] to select <YES>to delete document, or use [ ] to select <NO> not to delete the document.
Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
