Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A Logo
A
Anonymous Posted on Feb 11, 2014
Replace control on fmc7dnawh - Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A
Kenmore elite chest freezer control not working or illuminating. Good battery. Freezer is working.will replacing control panel fixit? What else may be bad?
It may be a sensor. Don't replace a control center unless you have determined it's bad. The sensor has to be wired to the board controller. Usually smaller cable with 2 conductors. If it has an alarm then there may g e as many as 6 or 8 or more wires going to the board. Using your wire diagram Find the sensor for temp. Sometimes the ohm value is given on the wire diagrams. You will also need the temperature at the point the sensor is connected inside. Your ohm reading should be close to the temp given in a table or from the manufacturer. If it's close sensor ok. Take next step.
How do I fix a kenmore freezer c675-48290 whose temperature control does not seem to work; it runs continuously?
Thermostat temperature control device are faulty need to replace. Kindly contact with your local area repair man to replace it .
Hope answer the question
Quit working, screen reads OF
FO error may indicate a stuck keypad button. try to reset the alarm. if the error reoccurs replace the electronic control module. be sure to disconnect the power supply before replacing the control.
2helpful
3answers
Control board and wiring harness which are supposed to replace Frigidaire 242000406 are apparently not correct. I have now installed 2 of the new control boards and I am unable to get any power to the...
Hello Gentlemen;
My name is Peter; I am a retired field service refrigeration technician.
The two of you are on the right track.
The board that you replaced;
Substitution: 5303918498
The electronic control board controls the major electro-mechanical components in the refrigerator. When the electronic control board senses the compressor needs to run to cool the refrigerator, it sends voltage to the compressor and fans. It then receives input from temperature sensors to monitor the temperatures inside the refrigerator and freezer sections.
This is a substitution and can not communicate with your existing electrical control board. You need tor replace this board was well:
Substitution: 241973711 Cost: $83.00
The electronic control board 241973711 controls the major electro-mechanical components in the refrigerator. When the electronic control board senses the compressor needs to run to cool the refrigerator, it sends voltage to the compressor and fans.
When you plugged in your old board and got power, that is because the two boards were communicating.
When you change the board be careful to ground yourself by touching something that is bare metal. Static electricity will knock out a board.
The Electrolux Frigidaire Refrigerator is a good unit. It should last you 20-30 years. If you want a unit that is in constant repair, buy either a Samsung or LG. They have the highest failure and repair cost of all of the manufacturers.
My Frigidaire freezer MFU17F3GW6 stopped running. The temperature got to 45 degrees. I turned the temperature control dial and the freezer ran all the way to zero, the set temperature and shut off. It...
Sounds like you need to replace the cold control. You can order the part online and then do a Google search for a video on how to replace it. You'll have remove some sheet metal inside the freezer, re-string the capillary and mount the control, then replace the 2 wires on it. Not a big deal if you're handy.
Jan 10, 2018 • Freezers
Glrs237zdw temp goes from 29 to 60
I am not sure if you said you checked the=> 5303918476 Defrost Control Board or here=> 5303918476 If you replaced the defrost thermostat inside the freezer that is most likely not the problem. These defrost control boards will really cause strange things to happen. Sometimes by unplugging and taking out the control board you will see burn marks or signs of heat damage on the printed circuit, not always. Unplug and open the control panel inside the fresh food compartment=> GLRS237ZW2 Control Panel
You will see part/location number 23 is your 5303918476 Defrost Control Board If I misunderstand please let me know so I can help you resolve this problem. Thanks Sea Breeze
Tryed to lower temp frig went to off position , tryed to unlock the control to no avail, also tryed the unplug no good, pls help thanks
On this style unit if the control will not respond then it will need to be replaced. Ussally a hard restart by unplugging the unit will clear this glitch, if you already did this then the control will need to be replaced in order to fix this issue.
http://www.appliancerepairlesson.com/
Can i replace the control panel on 60l engel?
yes you can replace the control panel
Feb 20, 2010 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
